SOMMERCABLE SC-KOLORITH 1 Hybrid Power and Data Cable
New
The SC-Kolorith 1 from Sommercable is a hybrid cable designed to transmit both audio data and power in a single line, making it an ideal solution for demanding installations in studios, architectural lighting, home automation, or smart sound systems.
Reference : 21518
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 07-04-2026.
Câble vendu au mètre
Sommercable SC-Kolorith 1 Hybrid Power and Data Cable 2x2mm² + 2x0.38mm²
The SC-Kolorith 1 from Sommercable is a hybrid cable designed to transmit both audio data and power in a single line, making it an ideal solution for demanding installations in studios, architectural lighting, home automation, or smart sound systems. Thanks to its shielded twisted pair (110Ω impedance) and 2mm² power conductors, it ensures reliable signal transmission and stable power supply up to 50V, even over long distances (up to 1000m). Its compact, flexible, and UV-resistant design makes it a suitable choice for both indoor and outdoor applications.
This cable is particularly recommended for connecting Meyer Sound low-voltage/smart products, lighting systems, or building management installations. Its AL/PT foil shielding and OFC copper conductors ensure excellent protection against interference, high electrical conductivity, and increased durability, even in complex environments.
Sommercable SC-Kolorith 1: Combined data and power transmission
The SC-Kolorith 1 stands out for its ability to combine balanced audio signals and power supply in a single cable, simplifying installations and reducing clutter. The twisted pair for data, with an impedance of 110Ω, is specially designed for high-quality audio transmission, while the two 2mm² power conductors can carry voltages up to 50V with minimal losses. This versatility makes it a hybrid cable suitable for professional applications where reliability and performance are essential.
Sommercable SC-Kolorith 1: Robust and flexible design
With an outer diameter of 7.40mm and a UV-resistant PVC jacket, the SC-Kolorith 1 is both lightweight (87g/m) and durable, capable of withstanding temperatures ranging from -25°C to 70°C. Its internal structure, composed of 48 strands of 0.10mm tinned copper for the audio section, ensures excellent flexibility and a long service life, even after numerous bending cycles. The 100% shielding provides effective protection against electromagnetic interference, ensuring stable signal transmission.
Product typeHybrid power and data cable
Conductors materialOFC copper
Conductors numberAudio: 2
Power: 2
Conductors sectionAudio: 2x 0.38mm² (21AWG)
Power: 2x 2.0mm² (14AWG)
Outer diameterØ7.4mm
Signal transmissionSymmetrical
Outer sheath materialPVC
Number of channelsAudio: 1
Power: 1
ShieldingAL/PT foil
Shielding factor100%
Conductors insulationPP
UV resistanceOui
Temperature range-25°C / +70°C
Impedance110Ω
LengthSold by the meter
Diameter (mm)7.4
Number of conductors4
Insulation materialPolypropylene (PP)
ShieldingYes
Section (mm²)0.38
Section (mm²)2.00
Ground / ShieldingYes
SOMMERCABLE SC-KOLORITH 1 Hybrid Power and Data Cable 2x2mm² + 2x0.38mm²
The SC-Kolorith 1 from Sommercable is a hybrid cable designed to transmit both audio data and power in a single line, making it an ideal solution...
