Silver Plated OCC Copper Shielded Ø8.3mm
This high quality modulation cable provides excellent signal transmission at an affordable price. It consists of two silver plated OCC copper conductors, which provide excellent conductivity. Each conductor is insulated with a PE and PVC jacket. A silver-plated aluminum foil shielding considerably limits the impact of potential interference on the signal. The cable is finally covered with a double PVC jacket.
Product type | Interconnect cable |
Conductors | Silver plated OCC copper |
Conductors structure | 100 x copper wire 0.10mm 4 x copper wire 0.5mm |
Section | 2x 0.8mm² |
Shielding | Silver plated aluminum foil |
Conductors insulation | PVC PE |
Outside sheath | PVC |
Cable diameter | Ø8.3mm |
Quantity | Sold by the meter |
Diameter (mm) | 8.3 |
Number of conductors | 2 |
Insulation material | PE |
Insulation material | PVC |
Shielding | Yes |
Section (mm²) | N/A |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
Ground / Shielding | Yes |
Average votes 5.0 / 5 8 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
peter S.
Philippe P.
daniel c.
Adam S.
Hocine H.
