FURUTECH FP-202 (R) Banana Plugs Lockable Rhodium Plated Ø5.5mm (Set x4)
4.9 / 5
By buying this product you get 36 loyalty points
Reference : 2124
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 18-12-2025.
High performance banana plugs with Rhodium Plated Copper contacts .
Its use for the transit of low voltage signals is also justified by its low electrical resistance.
It is all the more effective in its role as a driver that it benefits here from the anti-magnetism proprietary processFURUTECH Alpha α, lequel takes place 2 steps:
1- Cryogenization of metals by -250 ° C with the aid of liquid nitrogen in order to consolidate their molecular structure and to improve their conductivity significantly.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled so as to leave no residual magnetic at the end of the treatment.
The FURUTECH FP-200R uses a tube connectionto ensure contact with the speaker terminals. When the plug is connected, the cylinder, divided into two parts along a sinusoidal line , ensures a constant and regular pressure over its entire surface.
Internally, the cable is fixed by means of 2 screws to the specially designed shape to maximize the contact surface, and ensure a firm and durable hold. The FP-202R can also be welded for increased reliability .
Characteristics :
  • Rhodium plated copper body treated with the anti-magnetism process "Furutech Alpha α"
  • Connection: Screw
  • Dimensions:
    • 12mm diameter
    • 26mm in height
    • 46mm in length
  • Compatible with cable up to 5.5mm in diameter
  • Delivered in box of 4 with wrench
Max cable diameter (mm)5.5
Mounting typeTo screw
ConnecticMale
ConnectorBanana
8 reviews
Very good quality but it affects the sound. I prefer the cooper version.
This review has been posted for FURUTECH FP-202 (R) Banana Plugs Lockable Rhodium Plated Ø5.5mm (Set x4)
trés bon achat
branché en double cablage à l ampli et cables nus aux enceintes,l apport de ces fiches banane est flagrant:+de dynamique,+de graves bien maitrisés,des aigus définis,donc une belle évolution de mon système hifi.
Super produit
Super produit idéal pour pour le bi-câblage pour les amplis qui ne possède pas de double sortie haut parleur, ou pour connecter un caisson de basse.
Très équilibrés !
De très loin les meilleurs fiches banane que j'ai eu ou essayé !
Sur mon système la difference à été flagrante : j'avais un léger creux de 0.5db sur la bande de 1 a 6Khz ( mesuré avec Rew et Dirac Live ) que je mettais sur le dos de la pièce et que j'aurais sans doute modifié en changeant une resistance sur mes filtres d'enceintes , jusqu'à présent j'utilisais un mini dsp SHD pour corriger le creux , c'est simple quand j'ai changé les fiches bananes je suis dis mince j'ai laissé le filtre acoustique allumé , comme il n'était pas activé j'ai redémarré le mini dsp en me disant qu'il avait du planté avec le filtre sur on , et bien non !!
J utilise un cable enceinte de 5.5mm² 1000 brins cuivre plaqué argent d'une marque allemande qui n'existe plus et ces fiches sont un exemple d'équilibre sur tout le spectre et surtout de transparence !! rien n'est mis en avant ou en arrière tout est d'un équilibre d'une subtilité d'une justesse et d'une intimité parfaitement dosé ( en tout cas sur mon système )
Pour information: j'utilise le câble nu sur mes bornier d'enceinte et j'utilise ces fiches sur les borniers de mon ampli qui ne sont pas percés et qui remplacent de précédentes fiches plaqués or.
Mon système : Ampli Kinki Studio Exm1+ ( mon plus gros coup de coeur de ces 4 dernières années ) dac Gustard X26Pro ( deuxième coup de coeur ) câble de modulation Plénitude Audio Signature ( un chef d œuvre de transparence ) enceintes 4 voies sur une base d Atlas MKV avec un filtre maison 1/3 Jantzen 2/3 Mundorf fabriqué par un ami passioné
Ces fiches complètent à merveille le dernier chainon manquant d'un ensemble que j'ai mis 4 ans à peaufiner pour enfin avoir le son que j'attendais.
Excellent
Très belle qualité de fabrication.
Profonde modification du son. Comparé aux fiches bananes en or que j'ai remplacé : des basses plus précises et fortes, des aigues mieux définis, beaucoup de transparence et de détail. Effet "loudness" typique du Rhodium, faire attention si vos câbles ont de l'argent, ou si votre son est déjà un peu sec.
