J'avais déjà acheté 4 fiches pour fixer sans soudure les câbles HP du côté de l'amplificateur.
J'ai acheté ensuite 4 autres fiches pour fixer les câbles HP du côté des enceintes.
La fixation est forte, le son est toujours au top.
Merci Audiophonics.
Screw Gold Tellurium copper plated banana
Give to your speaker cables a new life with this high-quality Pangea Xtreme connector. Xtreme bananas are specially designed to be welded or screwed in the easiest way in the world. These 100% Tellurium copper connectors (98% IACS) ensure superior conductivity, thereby eliminating the linear resistance of competing brass and phosphorous bronze connectors.
The result is immediately obvious with firmer and low distorted bass, a lower-pitched high midrange that is less projected, less screaming and more precise.
Spécification | |
Type | Banana for loudspeakers wit screws |
Matérial | 100% Tellurium Copper IACS 98% conductivity |
Plated | Gold plated 24K |
Dimensions | Lenght 45mm x Diameter 9mm |
Banana Length | 17.8mm |
Internal capacity cable | Ø 5mm |
Colors | Copper gold |
Max cable diameter (mm) | 5.0 |
Mounting type | To screw |
Mounting type | To weld |
Connectic | Male |
Connector | Banana |
Contacts Material (Connector) | Tellurium Copper |
Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 14 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jean-Luc R.
Jean-Luc R.
Manfred D.
Marc M.
Nicolas T.
