WONDOM PS-BC12112 BCPB3 Battery Management System Module 5x Lithium 18650
The Wondom BCPB3 is a battery management and protection module, taking advantage of the performance and reliability of the previous models while offering more battery slots.  The BCPB3 can thus accommodate 5 Lithium 18650 batteries in series.
Reference : 14396
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 06-06-2025.
Wondom BCPB3 PS-BC12112
Wondom BCPB3 PS-BC12112 Module BMS d'Alimentation Charge de Batterie 5x Lithium 18650
The Wondom BCPB3 is a battery management and protection module, taking advantage of the performance and reliability of the previous models while offering more battery slots.  The BCPB3 can thus accommodate 5 Lithium 18650 batteries in series and can be used as a power bank, as a power supply or simply to recharge your batteries for external use.  The module supports a wide range of input charging voltages and hybrid charging sources.  Any 5-24V 2A AC adapter can be used to charge the batteries with the BCPB3.
The balancing and protection circuitry constantly monitors each cell voltage, charge/discharge current and temperature to provide effective protection against overloads, overdischarges, input/output overcurrents, short circuits and overtemperatures.
Lithium 18605 batteries are sold separately.
Product typeBMS module (Battery Management System)
Compatible battery typeLithium 18650
Number of battery slots5
Power voltage5-24V 0.5-2A
Power outputunregulated
Full load: 21V
Unloaded: 15V
Possibility of output 2x5V 2A regulated with a USB output module
ProtectionShort circuits
Over temperature
Over voltage
Under voltage
Overcharge
Overdischarge
Solar charging support
Multiple discharging ports
Max discharge current5A
Dimensions122 x 91.5 x 35mm
Weight168g
InputNC
InputPCB Connector
OutputPCB Connector
Output voltage (V)21.0
Output current (A)5.0
Input voltage (V)5.0
Input voltage (V)24.0
Power SupplyBattery
2 reviews
Très bien.
Fait parfaitement le job pour alimenter un préamplificateur phono. MAIS attention le set de câbles et leds n'est pas livré avec comme indiqué précédemment et il est quasi indispensable.
This review has been posted for WONDOM PS-BC12112 BCPB3 Battery Management System Module 5x Lithium 18650
très efficace
entièrement satisfait de ce kit qui gère bien la charge des batteries . on peut recharger en branchant un courant de 5 à 24v , y compris par panneau solaire et il se débrouille donc très pratique, le seul bémol c'est qu'il n'y a pas de bouton 'off' , donc le système tourne en permanence, pour çà prévoir des interrupteurs sur les sytèmes alimentés .
ce module est livré avec tout ses cables donc inutile de commander le pack de cable en option (PS-BC12311)
The Wondom BCPB3 is a battery management and protection module, taking advantage of the performance and reliability of the previous models while...
