SOMMERCABLE - SC-ELEPHANT SPM425
The cables are red ...
and the crowd roars when the loudspeaker volume is pushed to the maximum. Such a climax does not only cause overheating of the spectators' soul but also of the cables, which are also subjected to extreme stresses: their protective sheath must be as resistant as the skin of an elephant . And they must be flexible, robust, easily rollable, crush-resistant and able to withstand countless uses. The special ELEPHANT SPM4025 combined cable is one of the outstanding models designed specifically for woofer and surround systems. The SPM4025 consists of a total of 4 conductors with a cross-section of 2.5 mm². Due to its wiring mode similar to that of hi-fi drivers, the SPM4025 delivers absolutely pure treble and faithful and dynamic bass.
Make a comparison with other cables for speakers: the ELEPHANT will convince you in all areas!
Also available in FRNC version without halogen(test C) and version E30!
ADVANTAGES:
- Transmission of signals without loss, thanks to specially formed cores
- Very flexible, suitable for stage installations (PVC version only), easily rollable
- Compatible with common Neutrik-Speakon connectors
- Easy transformation thanks to the excellent insulation and numbering of the cores
USE:
- Professional Acoustic Equipment / Output Amp
- Surround and woofer systems
- Fixed building installations
Technical characteristics:
Constitution | (4LIY2.5mm 2 ) Y |
| r "> Envelope, diameter | PVC 10.2 mm |
AWG | 13 |
Number of Conductors | 4 x 2.5 mm 2 |
Envelope material, insulation | HM2 (C mode halogen free) PVC |
Copper strands per core | 78 x 0.20 mm |
Conductor insulation, diameter | 3.05 mm |
Operating temperature | min. -25 ° C |
Operating temperature | max. 70 ° C |
Fire resistance per m | 0.49 kWh |
Weight per m | 160 g |
Color of envelope | black |
Packaging, packaging unit | per meter |
Electrical Specifications:
Odometer Resistance, Conductor | <7.7 Ohm |
Resistance, insulation | > 5 MOhm |
Operating voltage | max. 300 V |
Test voltage | 2 kV |
Reference No. </ Span> | 490-0051-425 |
