LUXSIN X8 DAC Headphone Amplifier Preamplifier
The Luxsin X8 is a high-end all-in-one audio solution designed for demanding audiophiles, combining the functions of a DAC, headphone amplifier, and preamplifier. As such, it combines a powerful digital-to-analog converter, a headphone amplifier capable of driving even the most power-hungry headphones, advanced DSP with AI-assisted equalization, an intuitive touchscreen, and comprehensive connectivity in a high-quality CNC-machined aluminum chassis.
Reference : 21442
699,00 €tax incl.
582,50 € tax excl.
Shipping date: 18-11-2026.
Luxsin X8 DAC Headphone Amplifier Preamplifier DSP WiFi Bluetooth 5.1 8xCS43198 32bit 768kHz DSD512
Photo du Luxsin X8
The Luxsin X8 is a high-end all-in-one audio solution designed for demanding audiophiles, combining the functions of a DAC, headphone amplifier, and preamplifier. As such, it combines a powerful digital-to-analog converter, a headphone amplifier capable of driving even the most power-hungry headphones, advanced DSP with AI-assisted equalization, an intuitive touchscreen, and comprehensive connectivity in a high-quality CNC-machined aluminum chassis. The goal of the X8 is to provide a customizable, detailed, and immersive listening experience for any modern desktop or home studio audio setup.
L'intérieur du Luxsin X8
Luxsin X8: 8 CS43198 DACs in dual mono parallel architecture
The Luxsin X8 features an ambitious DAC architecture based on eight Cirrus Logic CS43198 chips mounted in a dual-mono configuration with four DACs per channel. This approach allows for complete separation of the left and right channels (power supply, circuits, and signal paths), which significantly reduces noise and crosstalk and improves dynamics and signal-to-noise ratio. Each DAC is protected by dedicated shielding to minimize interference and optimize the reproduction of fine details. The X8 supports high-resolution playback up to 32bit 768kHz PCM and DSD512, ensuring ultra-precise conversion and a stable, deep sound image.
Architecture DAC du Luxsin X8
Luxsin X8: Powerful headphone amplifier
The amplification section of the Luxsin X8 is designed to deliver generous power and refined musicality. Thanks to optimized amplification using multiple OPA1612 operational amplifiers and TPA6120A2 high-current drivers, the device delivers up to ≈4800mW per channel (on balanced outputs) with very low distortion and excellent linearity. Three headphone outputs are available: balanced XLR4, balanced 4.4mm, and single-ended 6.35mm, ensuring compatibility and power for a wide variety of headphones and earphones. An intelligent automatic impedance detection system adjusts the optimal gain according to the connected headphones, for consistently accurate control.
Puissance d'amplification du Luxsin X8
Luxsin X8: Wi-Fi DSP & AI-assisted equalizers
One of the X8's strengths is its integrated DSP engine based on a dual-core HiFi-5 DSP + ARM STAR architecture, with sufficient computing power for advanced real-time audio processing. The X8 offers AI-assisted parametric equalization, allowing you to automatically adjust the sound signature or correct the frequency response according to your preferences via voice or text commands. A vast integrated database contains more than 2500 headphone profiles, facilitating personalized equalization tailored to each model. All these functions can be controlled from the screen, a mobile app, or a web interface.
Fonction DSP du Luxsin X8
Luxsin X8: Smart and flexible control
The Luxsin X8 also stands out for its advanced management via the Luxsin Controller ecosystem, offering unmatched flexibility of use: the device can be controlled not only from its built-in touchscreen, but also via mobile apps for Android/iOS, web control from a browser on Windows or macOS, and even with an optional infrared remote control. This ability to control it from different devices makes it easy to adjust all audio settings—equalization, custom PEQ profiles, DSP settings, volumes, and more—without being physically in front of the device. The X8's firmware is designed to be updated locally or online, ensuring that the user experience evolves and improves over time. The Luxsin Controller mobile app makes it particularly easy to select headphone profiles and adjust equalization, making sound customization more intuitive and accessible.
Contrôle du Luxsin X8
Luxsin X8: Touchscreen & VU Meters
The Luxsin X8 features a 4-inch color touchscreen (960 × 480), providing a rich and intuitive visual interface at the center of the device. This screen facilitates access to all system functions and real-time playback level monitoring. While listening, various VU meters, spectrum analyzers, or file resolution information can be displayed with customizable styles, making it both functional and aesthetically pleasing to use.
Écran du Luxsin X8
Luxsin X8: Independent Power Supplies
To ensure optimal audio performance, the Luxsin X8 employs a fully separated linear power supply for digital and analog circuits. This separation reduces interference and noise coupling, providing a clean electrical foundation that improves clarity, soundstage depth, and dynamics. The system incorporates voltage and current sensors to monitor power in real time, as well as an adjustable dual analog voltage design (12V/15V), increasing flexibility for different types of audio loads.
Alimentation du Luxsin X8
Luxsin X8 Overview
The Luxsin X8 has extensive connectivity, allowing it to adapt to a wide range of uses and audio configurations, with USB-B, USB-C, coaxial, optical, and IIS inputs compatible with high resolution up to 32bit 768kHz and DSD512, RCA and XLR analog outputs that can be used in DAC or preamplifier mode, as well as multiple balanced and unbalanced headphone outputs for maximum compatibility. 12V trigger ports complete the package, making it easy to integrate the X8 into a controlled or automated hi-fi system.
Aperçu du Luxsin X8
1Balanced 4-pin XLR headphone output
2Single-ended 6.35mm headphone jack output
3Balanced 4.4mm headphone jack output
44-inch screen
5Multifunction button: ON/OFF/VOLUME/MUTE
6Mains power supply
7Bluetooth antenna
8Trigger IN/OUT
9USB-B input
10USB-A port
11USB-C input
12WiFi antenna
13I2S input via HDMI
14Coaxial input
15Toslink optical input
16Balanced XLR pre-out
17Single-ended RCA pre-out
LUXSIN X8 tes by Audio Science Review
There is no question that Luxsin has built a premium DAC and HP amp in X8 in every regard. From superbly responsive and easy to use display to powerful headphone amplifier that can drive any headphone with ease, perfection is attempted. Performance is just a slight hair off from bleeding edge by a mere dB or two. In exchange, the X8 aces many other areas to the delight of this reviewer who has tested hundreds of such devices.
I am happy to recommend the Luxsin X8.
Product typeDAC
Headphone amplifier
Preamplifier
DAC chip8x CS43198
DSP chipDual-core HiFi-5 DSP and ARM STAR architecture
AmplificationOPA1612 + TPA6120A2
BluetoothQualcomm SXW5125 (BT 5.1)
Inputs1x USB-B input
1x USB-C input
1x I2S LVDS input via HDMI
1x Toslink optical input
1x Coaxial input
Bluetooth
Outputs1x Balanced XLR pre-out
1x Single-ended RCA pre-out
1x Balanced 4-pin XLR headphone output
1x Balanced 4.4mm jack headphone output
1x Single-ended Jack 6.35mm headphone output
Other connectorsUSB-A port for updates
Trigger IN/OUT
WiFi2.4GHz / 5GHz
Supported sample ratesUSB and I2S: PCM up to 32bit 768kHz, DSD up to DSD512
Toslink optical and coaxial: PCM up to 24bit 192kHz
Screen4" LCD touchscreen (480x960mm)
Control methodTouchscreen
Mobile app (Android/iOS)
Web browser
IR remote control (optional)
DSP
Balanced XLR pre-out specifications
SNR≥ 129.5dB
THD+N< -121.8dB @ unweighted
Crosstalk≥ 133dB (1kHz @ 200kΩ)
Noise floor< 1.1uVrms
Output level4.2Vrms (1kHz @ 200kΩ)
Single-ended RCA pre-out specifications
SNR≥ 124.5dB
THD+N< -120dB @unweighted
Crosstalk≥ 125dB (1kHz @ 100kΩ)
Noise floor< 1.3uVrms
Output level2.1Vrms (1kHz @ 100kΩ)
Balanced headphone output specifications (4.4mm/XLR4)
Gain high+R ≥ 4840mW + 4840mW (16Ω,THD+N < 1%)
Output impedance< 1Ω
THD+N< -117dB (1kHz/0dB @ 32Ω)
SNR≥ 123dB
Crosstalk≥ 119dB (1kHz @ 32Ω)
Single-ended headphone output specifications (6.35mm)
Gain highL+R ≥ 2900mW + 2900mW (16Ω,THD+N<1%)
THD+N< -115dB(1kHz/0dB @ 32Ω)
SNR≥ 121dB
Power supplyAC 100-120V/220-240V~50/60Hz
Energy consumption25W
Dimensions236mm (L) × 236.8mm (W) × 64mm (H)
Weight2.75kg
Package1x Luxsin X8
1x USB-B cable
1x 3.5mm to 6.35mm jack adapter
1x AC power cable
InputI2S via HDMI
DAC / ADC ChipCS43198
Max sampling rateDSD512
Max sampling rate768kHz
NetworkingYes
Remote ControlControl app
2 reviews
Excellent DAC très dynamique
Excellentes performances et fonctionnalités uniques. Je recommande d'installer le dernier Firmware pour une meilleure stabilité WIFI.
This review has been posted for LUXSIN X8 DAC Headphone Amplifier Preamplifier DSP WiFi Bluetooth 5.1 8x CS43198 32bit 768kHz DSD512
Très bonne machine
J'avais eu l'eversolo z8, je l'avais trouvé très bien mais là sortie casque n'était pas assez puissante.
Là on a un peu la même machine mais avec une sortie casque très puissante, et en plus l'accès au peq et à des bases de données.
J'avais récupéré un pdf oratory pour he1000 v2, je trouvais le son mauvais, j'ai cherché et j'ai failli tout renvoyer.
J'ai testé les courbes de la base de données via le peq luxsin, j'ai pris une Harman 2013, baissé un peu le grave, monté un peu le high shelf aigu et tout est rentré dans l'ordre. L'eq oratory que j'avais bouffait trop de medium donc le son était nasillard.
Maintenant j'écoute sans plus me poser de question.
Vraiment une très belle machine, eversolo est pour moi une des meilleures marques chinoises.
The Luxsin X8 is a high-end all-in-one audio solution designed for demanding audiophiles, combining the functions of a DAC, headphone amplifier,...
