The connectors are very well made, strong and elegant. The quality of the copper is absolutely top of the notch, and it sound as hi-end as the famous Oyaide SSC copper cable. I higly recommend this connectors for a serious upgrade
Gold Plated Pure Copper Binding Post ⌀19x54mm (Pair)
The ETI BP-20C are very high performance terminal blocks at contained prices. Made of 1100 Series Hardened Copper conductor with 102% IAC (conductivity index), these terminals provide an audio signal that will not be degraded.
In addition, the BP-20C has a gold plating, applied without the use of Nickel. Indeed, if many manufacturers use Nickel before gold plating in order to offer greater brilliance on contact, this also has the effect of reducing conductivity, and therefore the quality of the audio signal.
On the structure side, these terminal blocks are adorned with an Aluminium body and Polymer rings. The Polymer ring allows to have no conductive material in contact with Copper and Aluminum is an excellent material to reject EM/RF noise that could disturb the signal.
Nothing could be easier to assemble. If it is of course possible to fix your cable by welding, the BP-20C also offers a screw fixing system for greater ease of assembly.
ETI opts here for a 20mm long post, a length often adapted for mounting on a chassis but also on some speaker plates.
The nut used to fix the terminal blocks is made of a high density non-conductive polymer, so that no conductive material touches the copper post, except your cable.
Conductor material | Pure Copper (IACS 102%) |
Plating | Gold |
Housing material | Aluminium / Polymer |
Max length | 54mm |
Max diameter | 19mm |
Post length | 20mm + 6mm |
Drilling diameter | 11.2mm |
Max panel thickness | 5mm |
Connection type | To screw / To solder |
Max cable diameter | 4mm |
Sold by pair | 1x Black / 1x Red |
Weight (for one binging post) | 25g |
Colors | Black (+ red for red binding post) |
Mounting type | To screw |
Mounting type | To weld |
Connectic | Female |
Max panel thickness (mm) | 5.0 |
Accepts Banana Plugs | Yes |
Connector | Speaker terminal |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Luca D.
Fabian b.
Hendrik W.
Serge B.
