CL-99WB WiFi Bluetooth 5.0 Receiver Airplay2 DLNA HDMI USB Optical Bit-Perfect
The CL-99WB is an extremely convenient wireless receiver module, supporting both WiFi 2.4G/5G and Bluetooth 5.0, which will allow you to set up a powerful connected audio system, especially in DIY design. In addition to its wireless connectivity, it has a complete set of PH2.0mm connectors. There is an auxiliary input, optical SPDIF, HDMI and USB. For the outputs, the module provides auxiliary, optical SPDIF and I2S.
Reference : 16537
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 15-05-2025.
CL-99WB hifi version - bit-perfect
CL-99WB Récepteur WiFi Bluetooth 5.0 Airplay2 DLNA HDMI USB Optique
What is Bit-Perfect?
Bit-perfect is a term commonly used in audio to describe a player that can play a file without making any changes of any kind.
For example, if your CL-99WB player plays a 24bit 192kHz Hi-Res file on Qobuz, the digital output will offer 24bit 192kHz. Just as if the music file played is in 16bit 44.1kHz, the digital output will propose this same sampling rate, without modification. In short, a real 1:1 ratio (input/output).
This is what we call a real bit-perfect reading, the closest to the musical reality of the piece played.
Multiroom & Streaming
Based on a LinkPlay module, the CL-99WB can be integrated into a multi-room ecosystem. It becomes possible to broadcast music in several rooms of the house, synchronously or asynchronously, all remotely controllable from your smartphone.
In addition, through the use of a control application it becomes possible to access many streaming services, such as Spotify, Tidal, Qobuz, Deezer or webradios such as iHeartRadio and TuneIn.
Pinout
NameTypeFunction
1GNDGND5V power supply negative pole
25VPWR5V power supply positive pole
3VCCPWRVCC 5V outputUSB Interface
4DMI/OUSB_DM
5DPI/OUSB_DP
6GNDGNDGND
7LINRIRight channel AUX inputAUX input
8GNDGNDGND
9LINLILeft channel AUX input
10ROUTORight channel AUX outputAUX output
11GNDGNDGND
12LOUTOLeft channel AUX output
13AMP_MUTEOAmplifier mute pin-output
14IRIIR signal receiving pinIR Receiver
15GNDGNDGND
16VCCOVCC 3.3V output
17KEY0CTLMode conversionLong press for WPS/pairing
18ADC_KEYIADC key input pin
19Optical_LEDOOptical fiber indicator
20USB_LEDOU Disk play indicator
21Aux_LEDOAUX input indicator
22HDMI_LEDOHDMI indicator
23BT_LEDOBluetooth indicator
24WiFi_LEDOWiFi indicator
25GNDGNDGND
26MCLKOMCLK of I2S output
27LRCLKOLRCLK of I2S output
28BCLKOBCLK of I2S output
29DOOData out of I2S output
30GNDGNDGND
31VCCOPOVCC 3.3V outputOptical input
32GNDGNDGND
33SPDIFISPDIF signal input
34CECI/OHDMI CEC controlHDMI (ARC) input
35GNDGNDGND
36ARCIHDMI audio return
37I2C_SCLI/OSCL I2C HDMI
38I2C_SDAI/OSDA I2C HDMI
39HDMI_5VO5V HDMI output
40DECTIHDMI ECT pin
41GNDGNDGND
42GNDGNDGNDUSB ETH extension interface
43DPI/OUSB_DP
44DMI/OUSB_DM
45VCCPWR5V VCC output
46SPDIFISPDIF signal outputOptical fiber output
47GNDGNDGND
48VCCOPO3.3V VCC output
Product typeWiFi / Bluetooth receiver
InputsWiFi 2.4G & 5G
Bluetooth 5.0
1x AUX
1x SPDIF
1x HDMI
1x USB
Outputs1x AUX
1x SPDIF
1x I2S
Output sensitivityAUX Output: 1V (1kHz, 0dB)
I2S Output: 0dB (1kHz, 0dB)
THD0.03%
SNR95dB
Supported file formatsMP3, AAC, FLAC, ALAC, WMA, APE, WAN, OGG
Supported streaming servicesSpotify, Tidal, Qobuz, Napster, TuneIn, iHeartRadio
Supply voltage5VDC 1A
Dimensions70 x 60mm
Package1x CL-99WB
1x Remote control
Cables
InputPCB Connector
InputWiFi
OutputPCB Connector
Confirmed HDMI ARC
I can confirm that this module can provide audio from your TV to your speakers over an HDMI ARC connection. Volume control and power on/off are all working. You have to purchase a separate female HDMI PCB board that has pin outs. Find an HDMI pin out diagram and then match the pins on the HDMI PCB to the inputs on the cl-99wb. That's it, you're all set after that. This little board is perfect for a diy preamp or integrated amp with rich digital and wireless connections. I haven't tested the DAC on the cl-99wb as I'm using the i2s out to an r2r dac
This review has been posted for CL-99WB WiFi Bluetooth 5.0 Receiver Airplay2 DLNA HDMI USB Optical Bit-Perfect
The CL-99WB is an extremely convenient wireless receiver module, supporting both WiFi 2.4G/5G and Bluetooth 5.0, which will allow you to set up a...
