Bluetooth Receiver Module 4.2 CSR64215 with ES9023 DAC
Bluetooth Receiver 4.2 CSR64215 with ES9023 DAC
This module includes both a CSR 64215 Bluetooth receiver and an ES9023 DAC. A solution both practical and powerful for a low pricing.
Reference : 12484
24,90 €tax incl.
20,75 € tax excl.
Accessories
Bluetooth receiver and DAC
CSR64215 & ES9023
récepteur bluetooth csr64215 et dac es9023
Efficient Bluetooth reception...
For its Bluetooth reception section, this module is equipped with a Qualcomm CSR64215 chip. This one offers excellent features, giving it a flawless reception, for a neat audio reproduction. Thus, this one was thought especially for an audio use. In addition, the chip takes advantage of Bluetooth 4.2 and A2DP for higher data transmission speed and stability. The module also supports the aptX and aptX Low-Latency codec, allowing you to achieve audio quality very close to that of the CD.
... Backed by a high quality DAC
The module also includes an ES9023 ESS DAC ESS for the Digital/Analog Conversion section. This chip, now recognized, allows you to achieve excellent audio performance at a low cost. This one uses the Hyperstream and Time Domain Jitter Eliminator architecture allowing a drastic reduction of the jitter.
High quality components
Although this module is offered at a very reasonable price, it also includes components of the highest quality. This includes, for example, a JFET operational amplifier to reduce the output impedance, Nichiconn Panasonic or WIMA capacitors, or an oscillator to reduce the jitter.
Bluetooth ChipQualcomm CSR64215
Bluetooth type4.2
Bluetooth Technologies / Codec / ProtocolsA2DP
aptX Support
aptX Low-Latency Support
DACESS ES9023
DAC Architecture & TechnologieHyperstream
DNR112dB
THD+NAt 0dBFS : 0.002% (Max. 0.006%)
OutputJack 3.5mm
Power supplyMicro USB 5V
Dimensions62 x 59 x 15mm
ComponentCSRA64215
ComponentES9023
OutputJack 3.5mm
Colissimo - TNT - SoColissimo
Excellent !!!
Réellement très surpris par la qualité de traitement du signal, rendu vraiment pertinent, les aigus sont au rendez-vous tout comme les graves, il n'y a pas de découpage des fréquences grossier... Totalement satisfait !! Ultra compact pour une dissimulation absolu, utilisation basique, connexion simplissime.
This review has been posted for Bluetooth Receiver Module 4.2 CSR64215 with ES9023 DAC
