iFi Audio's Zen Blue 3, successor to the Zen Blue 2, is a high-end Bluetooth receiver. It features a new Bluetooth chip, the QCC5181, the most advanced model in Qualcomm's 5100 series to date. This Bluetooth receiver chip enables it to support high-resolution codecs : SBC, AAC, aptX Lossless, aptX Adaptative, aptX HD, LDAC and LHDC for lossless wireless transmission. It is also capable of transmitting streams wirelessly to Bluetooth headphones or earphones.
Added to this is an ESS ES9023 DAC chip with jitter eliminator, enabling a dynamic range of 112dB, as well as use of the ZEN Blue 3 as a USB DAC (24bit/96kHz). It also features an optical Toslink/coaxial input on 3.5mm jack (24bit 192kHz) and analog stereo RCA. iFi Audio has opted for a balanced circuit with stereo RCA, balanced 4.4mm jack and Toslink/coaxial optical output on 3.5mm jack. Not only does the Zen Blue 3 benefit from numerous technical improvements, it also boasts a new look to match the brand's other devices, and a much more comprehensive control interface on the front panel. All these features make it a device of choice.
iFi Audio's Zen Blue 3 supports the high-definition codecs SBC, AAC, aptX Lossless, aptX Adaptative, aptX HD, LDAC and LHDC, thanks to its Bluetooth QCC5181 receiver chip, and is certified HWA (Hi-Res-Wireless Audio). The Zen Blue 3 is therefore able to receive CD-quality sound in wireless transmission (aptX lossless - 1200 kbps).
The Zen Blue 3 can also function as a wired DAC, thanks to its digital/optical inputs and ES9023 DAC chip. It supports 24bit 96kHz PCM streams via its USB input and 24bit 192kHz streams via its optical/SPDIF input via 3.5mm jack.
The Zen Blue 3 incorporates a MAX97220 amplifier chip, a CT5302 DSP and the brand's proprietary OV series OPAs. These OPAs deliver extremely low noise, low distortion (0.0001%) and wide bandwidth. The balanced circuit design also helps reduce noise, crosstalk and interference for a clearer sound.
1 | ON/OFF button |
2 | Operating mode selection |
3 | Bluetooth antenna |
4 | Transmission mode & low latency |
5 | Brightness and Bluetooth pairing |
6 | Source selection |
7 | Display codecs and PCM format |
8 | Sampling rate kHz LED indication |
9 | Balanced 4.4mm jack output |
10 | RCA input |
11 | Optical/SPDIF input on 3.5mm jack |
12 | DC 5V power supply port |
13 | RCA output |
14 | Optical/SPDIF output on 3.5mm jack |
15 | USB-C input |
16 | Bluetooth antenna connector |
Product type | Bluetooth receiver |
Bluetooth chip | QCC5181 |
DAC chip | ES9023 |
DSP | CT5302 |
Amplification chip | MAX97220 |
OPA | Custom OV series |
Inputs | Bluetooth 1x USB-C 1x SPDIF/ Optical via 3.5mm jack 1x RCA stereo |
Outputs | 1x Stereo RCA line output 1x Balanced line output 4.4mm jack Bluetooth |
Bluetooth standard | Bluetooth 5.4 |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX Lossless, aptX adaptative, aptX HD, LDAC, LHDC |
Supported sample rates | USB: PCM 24bit 96kHz Optical/SPDIF 3.5mm jack: PCM 24bit 192kHz |
Operating modes | RX mode: Bluetooth reception TX mode: Bluetooth transmission DAC mode: Wired operation |
Output voltage | Balanced 4.4mm jack: 4.1Vrms (0dBFS@1kHz) RCA: 2.05Vrms (0dBFS@1kHz) |
Output impedance | Balanced 4.4mm jack: ≤ 102Ω RCA: ≤ 51Ω |
SNR | 109dB |
DNR | 109dB (0dBFS @ 1kHz) +A |
THD+N | < 0.005% (10Kohm de charge @20-20kHz) |
Power supply | USB-C ou DC 5V/≥0.5A (centre +ve) |
Energie consumption | <1W |
Dimensions | 158 x 115 x 35mm |
Net weight | 447g |
Package | 1x iFi Audio Zen Blue 3 1x Pair of RCA interconnect cables 1x USB-A to USB-C 1x Mains adapter |
Input | RCA |
Input | Bluetooth |
Input | USB |
Input | Jack 3.5mm |
Output | Jack 3.5mm |
Output | Bluetooth |
Output | RCA |
Output | Jack 4.4mm |
DAC / ADC Chip | ES9023 |
Color | Gray |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | LDAC |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
Supported Bluetooth codecs | aptX Adaptive |
Supported Bluetooth codecs | HWA LHDC |
Supported Bluetooth codecs | SBC |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX LL |
