I had to return my BC3 after 5 months of operation as it suddently stopped functionning. Audiophonics provided me with a new product (thanks for a good ASS process) but one can wander if the manufacturing quality is at rigth level.
Bluetooth Receiver 5.0 aptX-HD / LDAC & DAC ES9018Q2C 24Bit-96kHz
The BC3 from Topping is a High-Res Bluetooth Wireless Receiver on battery with integrated DAC.
Thanks to its CSR8675 Bluetooth chip, the device supports the best Bluetooth audio standards available to date (BT 5.0 SBC / AAC / apt-X / aptX - LL / apt-X HD / LDAC) and can handle sampling frequencies up to 24bit - 96kHz.
Its wide range of connectors (Mini-Toslink, Line output, headphone output) makes it an ideal solution for easily connecting your bluetooth audio sources to your DACs, integrated amplifiers or headphones.
Its analog audio circuit also benefits from an ESS ES9018Q2C DAC offering excellent audio performance with THD+N <= 0.002% @ 1kHz on its headphone output and <0.001% on its line output for a noise level <2.3uVrms.
The BCE3 receiver has a CSR8675 5.0 bluetooth chip on board that is compatible with the following protocols:
The CSR8675 chip can receive digital audio streams with a sample rate of up to 96kHz-24bit for very high quality wireless reception.
The device is therefore Hi-Res Audio Wireless certified.
The analog outputs (line output and headphone output) make the most of a decoding circuit based on an ES9018Q2C DAC chip.
This chip incorporates its own headphone amplification circuit capable of directly driving your headphones without going through an external amplifier. A simple and efficient way to use your wired headsets & IEM with a Bluetooth source while taking advantage of an excellent battery.
The line output is ideal for adding high quality Bluetooth connectivity to your integrated amplifiers or active speakers. It is also a very practical tool for adding bluetooth connectivity to a car's on-board sound system: once the line output of the BC3 is connected to the line input, each passenger can send their audio files independently.
When not used as a line output, the 3.5mm output can also be used as a digital SPDIF output on mini-toslink port.
A mini-toslink to toslink adapter is provided to allow you to easily connect all kinds of digital audio devices.
This output allows you to connect your bluetooth sources to a DAC or DSP that does not have a native Bluetooth input in order to use it wirelessly and easily switch between audio sources.
With a suitable source, it is thus possible to send a 96kHz bluetooth LDAC signal to the BC3 and to recover an SPDIF signal without degrading this high sampling rate on the mini Toslink output.
Topping's BC3 nomadic Bluetooth 5.0 receiver has an 800mAh battery.
The latter follows a 3-hour charge cycle and can easily last 11 hours of once fully charged.
Charging is done with ease using the supplied USB-C cable.
Specifications | |||
Type | Bluetooth Receiver DAC | ||
Bluetooth Chip | CSR8675 | ||
Bluetooth Norm | 5.0 | ||
Bluetooth Protocols | SBC / AAC / apt-X / aptX - LL / apt-X HD / LDAC | ||
DAC Chip | ES9018Q2C | ||
Inputs | Bluetooth | ||
Outputs | Headphone Out - jack 3.5mm Line Out / mini-toslink - jack 3.5mm | ||
Output level | Headphone Out : 2Vrms @0dBFs Line Out: 2Vrms @0dBFs | ||
THD+N@A-wt | Sortie casque : inférieur à 0.02% @1kHz Sortie ligne: inférieur à 0.01% @1kHz | ||
Noise@A-wt | < 2.3Vrms | ||
Volume | Volume control 32-steps | ||
Receiving distance | 10m max | ||
Battery | 800mAh | ||
Batterie use | @ Headphone Out 32Ω : ~12 hours @ Mini-toslink Out: ~11 hours @ Standby: ~25 days Charge time : 3 hours | ||
Dimensions | 60 x 60 x 17.5 mm | ||
Weight | 82.5g | ||
Color | Black |
Package contents | |
Bluetooth receiver / DAC Topping BC3 | x1 |
Cable USB-A male to USB-C male | x1 |
Adapter Mini-toslink male to toslink female | x1 |
Input | Bluetooth |
Output | Optical Mini-Toslink |
Output | Jack 3.5mm |
DAC / ADC Chip | ES9018Q2C |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Average votes 4.3 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Nicolas Q.
Paulo M.
