Transmitter / Receiver Bluetooth 5.1 DAC SPDIF 24bit 96kHz USB File Player
This Bluetooth 5.1 receiver/transmitter and DAC combo turns a classic audio integration into a versatile and practical wireless audio system. It will allow you to wirelessly stream your music from a source such as a smartphone or tablet, or transmit the audio stream from a connected source to headphones or an active speaker.
2.0 / 5
Reference : 17295
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 16-04-2026.
Récepteur / Émetteur Bluetooth 5.1 DAC SPDIF 24bit 96kHz Lecteur de Fichiers USB
In addition to its Bluetooth capabilities, the device has a complete connectivity with optical, coaxial and USB-A (for USB storage device). It also embeds combo input/output in stereo RCA and Jack 3.5mm formats. It also comes with an IR remote control for remote control.
1ON/OFF Switch
Volume button
2Previous track
3Play/Pause
4Next track
5USB-A input (USB Host)
6IR Receiver
7Input selection
8Coaxial / Optical input LED indicator
9Bluetooth input LED indicator (blue=reception / red=transmission)
10USB input LED Indicator
115V USB-C power supply
12Bluetooth antenna
13Jack 3.5mm input/output
14Stereo RCA input/output
15Coaxial input
16Optical input
17Play/Pause
18ON/OFF
19Mute
20Previous track
21Next track
22Volume -
23Volume +
24Bluetooth input
25Bluetooth transmission mode
26Optical input
27Coaxial input
28AUX input
29USB-A input
30Rewind
31Fast forward
32Bluetooth reception mode
Product typeTwo-way Bluetooth receiver / transmitter
DAC
InputsBluetooth 5.1
1* Optical Toslink
1* Coaxial
1* Stereo RCA (in/out combo)
1* Jack 3.5mm (in/out combo)
1* USB-A (USB Host)
OutputsBluetooth 5.1
Supported sampling ratesPCM up to 24bit 96kHz
Supply voltage5VDC via USB-C
Dimensions107*52*21mm
Package1* Bluetooth receiver/transmitter
1* Jack 3.5mm cable
1* Remote control
1* RCA cable
InputJack 3.5mm
OutputBluetooth
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate96kHz
Remote ControlYes
Supported Bluetooth codecsN/A
Pas cher mais...
J'ai retourné ce DAC immédiatement après l'avoir reçu et testé pour les motifs suivants :
- Imprécision du potentiomètre : le niveau ne monte presque pas sur trois quarts de la course, puis monte d'un coup sur la fin (moyennement gênant car on peut régler le volume avec la télécommande)
- En mode Bluetooth, il y a des micro-coupures intempestives lors de la lecture de musique (même avec le smartphone posé à côté du DAC, rédhibitoire pour mon usage)
- La voix (de très mauvaise qualité) qui annonce la mise sous tension, le changement de source, etc. est toujours à un volume très fort, quelque soit le volume qu'on ait réglé avec le potar ou la télécommande. Assez gênant si votre ampli est réglé à un niveau élevé derrière, je trouve en plus cette fonction totalement inutile.
J'ai testé l'entrée optique avec ma TV, avec une paire d'enceintes actives sur la sortie rca, ça fonctionne bien, correct pour le prix.
Je n'ai pas testé l'entrée coaxiale ni USB, ni la sortie Aux.
This review has been posted for Transmitter / Receiver Bluetooth 5.1 DAC SPDIF 24bit 96kHz USB File Player
This Bluetooth 5.1 receiver/transmitter and DAC combo turns a classic audio integration into a versatile and practical wireless audio system. It...
