XDUOO XQ-100 Bluetooth 5.0 Receiver CSR8675 aptX HD LDAC DAC 2x ES9038Q2M Balanced
With its XQ-100, xDuoo offers a very good Bluetooth 5.0 receiver, using a CSR8675 chip associated with a dual DAC ES9038Q2M. It offers excellent sound performance, while offering a practical wireless use, allowing a broadcast of your music directly from a smartphone or any other connected device. In addition, it has a particularly complete output connectivity, to integrate into most audio systems.
By buying this product you get 38 loyalty points
Reference : 15787
389,00 €tax incl.
324,17 € tax excl.
Shipping date: 07-04-2026.
xDuoo XQ-100
xDuoo XQ-100 Récepteur Bluetooth 5.0 CSR8675 aptX HD LDAC DAC 2x ES9038Q2M Symétrique
Bluetooth 5.0
Using a Qualcomm CSR8675 Bluetooth 5.0 receiver chip, the XQ-100 ensures stable signal reception. In addition, it supports the high-resolution codecs aptX, aptX LL, aptX HD and LDAC, allowing you to enjoy excellent wireless sound quality.
A rich output connectivity
The rear panel of the XQ-100 presents numerous outputs in various formats. As far as the digital part is concerned, there are Toslink optical and coaxial, the latter also acting as an output. For the analog section, the device provides both single-ended RCA and balanced XLR output.
1Optical Toslink output
2Coaxial output
3Bluetooth antenna
4Power button
5Balanced XLR output
6Single-ended RCA output
7Power supply connector
SRC Upsampling feature
The XQ-100's built-in SRC function allows it to upsample audio streams up to a sampling rate of 24bit 192kHz. It is thus possible to enjoy a better quality of sound reproduction even with lower resolution files.
OLED Screen
The front panel of the XQ-100 features an OLED display, showing essential information about the current playback. It shows the sample rate of the file as well as the sample rate after upsampling, the Bluetooth codec used and the title of the song.
Dual ES9038Q2M DAC
The digital to analog conversion stage of the XQ-100 is based on the use of two ESS ES9038Q2M chips. Each of them is responsible for one channel, allowing to reach a high SNR and an extremely low THD+N, for a very accurate reproduction.
SPDIF CS8406 Interface
These DAC chips are associated with a CS8406 SPDIF interface at the output, allowing the Bluetooth audio signal to be converted into a high quality signal for the optical and coaxial outputs.
Optimized power supply stage
The power supply stage has also been carefully designed, using a custom transformer ensuring great stability and a very low noise level. This one is associated with Nichicon filtering capacitors, allowing to provide a clean electrical signal to the audio circuits.
Product typeBluetooth Receiver
Bluetooth version5.0
InputsBluetooth 5.0
Outputs1x Optical Toslink
1x Coaxial
1x Single-ended RCA output
1x Balanced XLR output
Bluetooth chipCSR8675
DAC chip2x ES9038Q2M
SPDIF interfaceCS8406
Bluetooth transmission distanceJusqu'à 10m
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
Screen1.3" OLED
DistortionOptique : 0.00087%
Coaxial : 0.005%
RCA : 0.07%
XLR : 0.005%
Output levelOptical: 0.5Vp-p
Coaxial : 0.5Vp-p
RCA: 2V
XLR: 4V
Supply voltage100-120VAC
220-240VAC
Housing materialAluminum
Dimensions210 x 120 x 52mm
Weight1.2kg
ColorGray
Package1x xDuoo XQ-100
1x Bluetooth antenna
1x Power cable
OutputCoaxial SPDIF
OutputOptical Toslink
DAC / ADC ChipES9038Q2M
Max sampling rate96kHz
Max sampling rate192kHz
ColorGray
Supported Bluetooth codecsaptX
Supported Bluetooth codecsAAC
Supported Bluetooth codecsLDAC
Xduoo xq 100
Appareil reçu ce jour.....Envoi soigné et rapide.
Je n avais aucun doute sur la qualité de ce produit et la performance des puces qu' il embarque.
Une fonction bluetooth irréprochable.
Une fabrication haut de gamme et un design très élégant.
Audiophonics proposait le tarif le plus bas.....
This review has been posted for XDUOO XQ-100 Bluetooth 5.0 Receiver CSR8675 aptX HD LDAC DAC 2x ES9038Q2M Balanced
With its XQ-100, xDuoo offers a very good Bluetooth 5.0 receiver, using a CSR8675 chip associated with a dual DAC ES9038Q2M. It offers excellent...
