Cable Support Aluminium Steel
This cable support Viborg CB1 will allow you to raise your cables and operate a practical and aesthetic cable management system. This elevation can also limit the mechanical stress of a heavy cable on a connector.
The Viborg CB1 consists of a base, rods and supports. The base weighs 1.5kg and provides excellent stability. The rods can be screwed to each other to adapt the height of the supports.
Product type | Cable support |
Materials | Base : Aluminium Rods : Stainless Steel Supports : Aluminium |
Base diameter | 105mm |
Base weight | 1.5kg |
Total weight | 2.8kg |
Package | 1x Base 2x Supports 8x Rods |
