Cable kit DIY Yarbo Sector FI-E11CU + FI-11CU 2.5m
By buying this product you get 25 loyalty points
Reference : 8326
259,00 €tax incl.
215,83 € tax excl.
Cable Kit DIY Yarbo Sector and Connectors FI-E11CU + FI-11CU 2.5m
Audiophonics offers here cables in kit for more ease.
All necessary components are provided to build a complete high end power cable based on Yarbo and Furutech products.
This kit includes:
  • 2.5mx YARBO SP-1100PW Triple Shielded Cable Shield OCC 0.5m Ø 16.5mm
  • 1 x FURUTECH FI-E11CU Plug SCHUKO
  • 1 x FURUTECH FI-11CU IEC connector
  • 2 xViablue Protective cable end caps 6mm² OFC
  • 1 x Viablue Cable End Caps 4mm² OFC
Result when mounted:
https://www.audiophonics.fr/images2/8324/8324_kit_cable_yarbo_furutech_4.jpg
https://www.audiophonics.fr/images2/8324/8324_kit_cable_yarbo_furutech_5.jpg
If you want this cable mounted, we offer a mounting package.
Please go to
the following cardto take advantage of our offer:
https://www.audiophonics.fr/images2/5188/5188_CABLE_ASSEMBLY_5.jpg
YARBO SP-1100PW Triple Shielded Cable Copper Shield OCC
This cable consists of 3 conductors of large cross-section, has a double shielding against electromagnetic interference
This shielding is composed of a layer of PTFE per strands as well as a braid of copper shielding.
Each conductor is composed of several 7 strands of monocrystalline OCC copper (black and red), the earth of 3.
They are insulated with a layer of PTFE, copper strip then PVC./ P>
Despite its diameter of 16.5mm this cable is relatively flexible
It will guarantee a dynamic and detailed sound reproduction.
Features:/ Strong>
  • Phase and Neutral conductors: 7x1 mm = 5.53 mm² OCC insulation PTFE + copper strip + PVC sheath
  • Earth conductors: 4x1 mm = 3.16 mm² OCC insulation PTFE + copper strip + PVC sheath
  • The assembly is again shielded by a copper strip and a thick PVC sheath
https://www.audiophonics.fr/images2/6456/6456_YARBOSP1100PW_1.jpg
Cable also sold at the cut
IEC connector specifications:
  • Conductors: Copper alloy treated with the "Furutech Alpha α" anti-magnetism process
  • Insulation: Nylon / Fiberglass
  • Housing: Polycarbonate
  • This connector adapts to an external cable diameter of 6.6mm up to 18mm
  • 250V / 10A
  • Dimensions:
    • Diameter: 38mm
    • Body Length: 48.2mm
    • Overall Length: 74mm
https://www.audiophonics.fr/images/furutech_fi_11cu.jpg
IEC connector also sold individually
Connector specifications schuko :
  • Connectors Schuko 3 Screw Connectors
  • Plating:Or 24k 3μ
  • Maximum Driver Section:16mm² (4.5mm of Diameter)
  • Maximum Cable Diameter: 16.5mm
  • Voltage / Voltage Rating: 16A / 250V
  • Overall Length: 89 mm
  • Diameter: 38 mm
  • Weight: 75 g
https://www.audiophonics.fr/images2/8324/8324_kit_cable_yarbo_furutech_3.jpg
https://www.audiophonics.fr/images2/8324/8324_kit_cable_yarbo_furutech_33.jpg
Schuko connector also sold individually
Length (m)2.5
