best neutral cheap cable
Speaker Cable OFHC Copper Shielded 2x 1.65mm²
The Ramm Audio SA-15 is a speaker cable offering quality design at an affordable price. It consists of two OFHC copper conductors with a cross section of 1.65mm² (15AWG), ensuring high conductivity. Each conductor is then shielded by an aluminum-mylar foil and insulated by a high density PE jacket, effectively repelling interference. The whole is finally covered with a flexible PVC sheath.
Product type | Speaker cable |
Conductors material | OFHC Copper |
Conductors section | 1.65mm² (15AWG) |
Shielding | Aluminum-Mylar foil |
Insulation sheath | High density PE |
Outer sleeve | PVC |
Cable dimensions | 9.6*5.8mm |
Inductance | 1.17µh/m |
Resistance | 0.012Ω/m |
Capacitance | 60.5pF/m |
Color | Black |
Quantity | Sold by the meter |
Diameter (mm) | 9.6 |
Number of conductors | 2 |
Insulation material | PE |
Shielding | Yes |
Section (mm²) | 1.65 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Ground / Shielding | Yes |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Hugo Darien O.
Jerome C.
