Câble RCA Mono vers Jack 3.5mm Mono Plaqué Or 1.8m
This cable consists of a mono mâle RCA connector and a mono mâle 3.5mm jack. It may therefore allow you to connect some mono devices with these connections, such as the mono amplifier Audiophonics TPA-M50 which only has a 3.5mm mono jack connector at its input. The cable is also compatible with the Coaxial input in 3.5mm Jack format from SMSL AD18.
Reference : 14028
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 26-06-2025.
Jack / RCA Cable
Male Mono RCA to Male Mono Jack 3.5mm Gold Plated 1.8m
Câble RCA Mono Mâle vers Jack 3.5mm Mono Mâle Plaqué Or 1.8m
This cable consists of a mono mâle RCA connector and a mono mâle 3.5mm jack. It may therefore allow you to connect some mono devices with these connections, such as the mono amplifier Audiophonics TPA-M50 which only has a 3.5mm mono jack connector at its input. The cable is also compatible with the Coaxial input in 3.5mm Jack format from SMSL AD18. In addition, the cable connectors are gold-plated to ensure good conductivity and oxidation resistance.
Product typeMale mono Jack 3.5mm to male mono RCA cable
Length1.8m
Connectors platingGold
Length (m)1.8
ShieldingNC
Section (mm²)N/A
ConnectorRCA
ConnectorJack 3.5mm
This cable consists of a mono mâle RCA connector and a mono mâle 3.5mm jack. It may therefore allow you to connect some mono...
