OYAIDE PA-2075 RR V2 Phono Cable RCA-RCA
The OYAIDE PA-2075 RR V2 is an RCA-to-RCA phono cable featuring a high-end design that transmits a stable signal faithful to the original.
Reference : 19500
290,00 €tax incl.
241,67 € tax excl.
Shipping date: 03-04-2026.
Oyaide PA-2075 RR V2 Phono cable RCA-RCA Pure copper OCC Shielded with ground wire 1m
OYAIDE PA-2075 RR V2 cable picture
OYAIDE PA-2075 RR V2: OCC "102SSC" pure copper conductors
This cable features OCC "102SSC" pure copper conductors and a 3E multi-strand structure for enhanced conductivity. One of the special features of "102SSC" copper is that Oyaide removes 100% of impurities from the surface of the copper wire, polishing it with natural diamonds. 3E braiding" is a patented technology that geometrically twists strands of three different wire diameters to create a denser conductor.
The electrical capacitance of this cable is perfect for transmitting weak analog signals, thanks to its 110.0pF/m (1kHz) capacitance and 44 ohm impedance. It is therefore ideal for use with vinyl turntables.
102SSC copper
102SSC copper
3E structure
3E structure
OYAIDE PA-2075 RR V2: efficient shielding and insulation
A shielding system consisting of approximately three times the number of wires used for the conductor, plus a layer of PVC carbon, effectively protects the cable against interference. As insulation, Oyaide has chosen fluoroplastic (PFA) and a layer of polyethylene. The whole is covered by a halogen-free polyethylene outer sheath to dampen vibrations during signal transmission.
OYAIDE PA-2075 RR V2 cable structure
OYAIDE PA-2075 RR V2: high-end connectors and ground wire
The contacts of this cable's RCA connectors and ground wire are made of rhodium-plated copper alloy for greater resistance to corrosion and oxidation. The ground wire conductor is made of silver-plated copper for high conductivity, and its diameter has been increased for more effective grounding.
Technical ccharacteristics
Product typeRCA cable
Conductor materialPure OCC copper
ShieldingCarbon PVC
102SSC copper braid
InsulationPolyethylene and Fluoroplastic (PFA)
ConnectorsRCA to RCA
Connectors contacts materialCopper alloy
Connectors contacts platingRhodium
Cable/connector welding"SS47" lead-free silver solder wire
Cable conductors cross-section 0.5mm² (AWG20)
Capacitance110.0pF/m (1kHz)
Resistance44 ohms
Cable length1m
Total cable diameter5.2×12.4mm
External sheathHalogen-free anti-vibration
GROUND WIRE SPECIFICATION
Ground wire conductive materialSilver-plated copper
Ground wire cross-section0.3mm² (AWG22)
Connector materialRhodium-plated copper alloy
Package1x Phono RCA cable OYAIDE PA-2075 RR V2
Length (m)1.0
ShieldingYes
Section (mm²)0.50
ConnectorRCA
2 reviews
Un must
Un cordon phono qui à supprimer le petit bourdonnement dans mes hauts parleurs (non résolu avec mon ancien câble norstone à 70€)le tarif pique un peu mais le résultat est parfait,je recommande.matos:
Platine rega P3 rs
Ampli feez audio titania
HP bw 702 s2
Je félicite audiophonics pour la qualité de ses produits.
Jean Michel.
This review has been posted for OYAIDE PA-2075 RR V2 Phono Cable RCA-RCA Pure Copper OCC Shielded with Ground Wire 1m
Un must
Aigu lumineux, médium souple, grave ferme et bien détouré.
Système d'écoute: platine vpi classic 1,cellule Dynavector xx2, préphono Aurora Vida Phono.Un excellent rapport qualité prix.
