SMSL PL200 CD Player DAC AK4499EX + AK4191EQ USB XMOS Bluetooth 5.0 AptX HD LDAC 32bit 768kHz DSD512 MQA-CD
The SMSL PL200 is a high-quality CD turntable/player featuring an AKM AK4499EX DAC coupled with an AK4191EQ digital filter. This CD player is both high-performance and versatile. It is equipped with quality components such as the P.A.S.S (Precision Acces Servo System) servo playback system developed by SMSL, an USB XMOS interface on USB-C connector, OPA1612A, a Qualcomm Bluetooth 5.0 reception chip and many other audiophile components.
By buying this product you get 73 loyalty points
Reference : 18416
739,00 €tax incl.
615,83 € tax excl.
Shipping date: 20-05-2025.
SMSL PL200
The SMSL PL200 is a high-quality CD turntable/player featuring an AKM AK4499EX DAC coupled with an AK4191EQ digital filter. This CD player is both high-performance and versatile. It is equipped with quality components such as the P.A.S.S (Precision Acces Servo System) servo playback system developed by SMSL, an USB XMOS interface on USB-C connector, OPA1612A, a Qualcomm Bluetooth 5.0 reception chip and many other audiophile components. The design features a large IPS screen and piano keyboard buttons, for a perfect blend of modern and retro looks. Its wide range of connectors and versatile functions make it an ideal Hi-Fi device: MQA-CD CD player, Bluetooth receiver and USB DAC.
P.A.S.S playback system (Precision Acces Servo System)
SMSL has developed its own CD playback system providing audiophile levels of dynamic response and playback stability. In addition, an anti-vibration system and shock absorbers give this CD player a high level of reliability.
DAC AKM AK4499EX + AK4191EQ
The SMSL PL200 CD player features the AKM AK4499EX (DAC) and AK4191EQ (digital filter) chip combo. This enables it to support high-resolution streams up to PCM 32bit 768kHz, native DSD up to DSD512 and MQA/MQA-CD, with a distortion rate of less than 0.00006% (-123dB).
Bluetooth 5.0 receiver
A Bluetooth 5.0 receiver chip from Qualcomm enables the PL200 to work with high-resolution Bluetooth 5.0 codecs; SBC, ACC, aptX, aptX HD and LDAC (24bit 96kHz).
High-performance headphone amplifier
The PL200 features a 6.35mm jack headphone output with high-performance amplification circuitry and integrated PLFC.
High-end components
A CK-03 clock system with two highly accurate, low-noise clock sources reduces jitter considerably. The power supply stage incorporates low-noise components such as voltage regulators to increase the overall performance level of the PL200 CD player.
Sophisticated aesthetics: between modernity and retro look
The PL200 features piano keyboard keys for a retro look, and a large tempered-glass IPS display with a minimalist, modern interface. On the top of the PL200, an innovative cap covers the CD playback system. This can be removed to make CD playback more ceremonial. To use this function, simply remove the cover and press and hold the play button on the CD player.
The SMSL PL200's wide range of connectors
1Disc drive cover
2Disc holder capsule
3Disk slot
4Bouton Next
5Previous button
6Stop button
7Play/pause button
8Multifonction button
9IR receiver
10LED indicator
11Display
126.35mm jack headphone output
13Balanced XLR output
14RCA output
15Coaxial SPDIF output
16Optical Toslink output
17USB-C input
18Bluetooth antenna
19IEC power supply
Product type CD turntable / CD player
DAC chipAK4499EX
AOP3x OPA1612A
USB interfaceXMOS
InputsCD
Bluetooth
1x USB-C input
Outputs1x Stereo RCA output
1x XLR stereo balanced output
1x Coaxial SPDIF output
1x Toslink optical output
6.35mm headphone output
THD+N0.000068% (-123.5dB, un-wtd)
Dynamic rangeRCA: 127dB
XLR: 132dB
SNRRCA: 127dB
XLR: 132dB
Headphone output power2x 1000mW (32Ω)
USB transmission2.0 Asynchronous
USB compatibilityWindows 7/8/8.1/9/10/11 (with driver)
Mac OSX 10.6 et +
Linux
Suppported sample ratesUSB: PCM 32bit 768kHz, DSD512
Bluetooth5.0
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Power consumptionOperating: 10W
Standby: <0.5W
Dimensions200 x 42 x 175mm
Weight1.7kg
ColorSilver
Package1x SMSL PL200 CD player
1x Remote control
1x Power cable
6 reviews
avis d'audiophile averti et passionné
habitué aux appareils de format "conventionnels", j'ai mis un peu de temps à me décider...
Mais client Audiophonics de longue date, j'ai succombé à la tentation.
Associé à l'excellent ampli à tubes Cayin Jazz KT 88, enceintes Triangle Australe EZ, le résultat est bluffant.
Je ne passe pas mon temps à décortiquer le rendu des aigus, médiums et graves ; j'écoute mes cd et mes oreilles apprécient.
Le tout fait de la bonne, très bonne musique.
Le câble RCA Obsidian enfonce le clou.
Audiophonics, une entreprise honnête qui propose d'excellents produits et n'est jamais avare de conseils précieux.
This review has been posted for SMSL PL200 CD Player DAC AK4499EX + AK4191EQ USB XMOS Bluetooth 5.0 AptX HD LDAC 32bit 768kHz DSD512 MQA-CD
Excellent à tout point de vue
Commandé le mercredi soir, livré le samedi matin...parfait!
Excellent lecteur, que ce soit en CD, en Bluetooth ou comme dac externe USB de pointe pour mon lecteur réseau (merci la puce AKM 4499EX ), fonctionnement rapide et silencieux, affichage lisible, pieds antidérapants qui "collent" littéralement au support. Très bonne prise casque testée avec un HD 650 (mais située en face arrière, bizarre...). Interface intuitive on se familiarise avec les menus en 3 minutes. Bon rapport prix/musicalité/ fonctionnalités. Si on veut chipoter : j'aurais aimé une entrée numérique supplémentaire, une lecture sur stockage usb et une télécommande moins "cheap", mais comme il est c'est déjà un top lecteur.
Quelle affaire!
Après un week-end de test , je peux dire que ce lecteur n'a pas à rougir face à un ensemble de plus de deux fois son prix ( transport atoll +dac externe ess9038pro)
Le smsl est un petit peu moins précis dans les aigus, mais médium et grave au top.
La musique coule toute seule. A ce prix, une affaire.
Petit mais quels résultats impressionnants
Cela fait quelques mois que je possède le SMSL PL 200, et il s’est progressivement affirmé!
La musique s’exprime d’une façon naturelle, en largeur et profondeur. Les sons, la définition,
la musicalité, sont d’un naturel surprenant, je me suis remis à écouter mes CD et ma musique
pendant plusieurs heures, alors que précédemment à mon achat j’étais resté moins attiré par mes écoutes! Formidable appareil!
Un best-seller
Sans surprise, un excellent produit. La définition aussi bien dans le spectre haut que bas est excellente. La puce AKM du Dac n'est certainement pas étrangère à cet excellent résultat. Très satisfait d'autant que la livraison (vers la Belgique) fut très rapide.
Bravo Audiophonics !
The SMSL PL200 is a high-quality CD turntable/player featuring an AKM AK4499EX DAC coupled...
