TI LME49720NA/NOPB Operational Amplifier OPA Class AB 2 Channel DIP8 (Unit)
The Texas Instruments LME49720NA/NOPB is a high performance 2-channel Class AB, high performance operational amplifier (OPA) integrated in a DIP8 package. This ultra low distortion, low noise and high speed AOP is optimized for high fidelity audio applications.
4.3 / 5
Reference : 14413
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 19-11-2026.
TI LME49720NA/NOPB
Operational Amplifier OPA Class AB 2 Ways DIP8 (Unit)
TI LME49720NA Amplificateur Opérationnel AOP Class AB 2 Voies DIP8 (Unité)
The Texas Instruments LME49720NA/NOPB is a high performance 2-channel Class AB, high performance operational amplifier (OPA) integrated in a DIP8 package. This ultra low distortion, low noise and high speed AOP is optimized for high fidelity audio applications. Combining state-of-the-art technology and modern design, the LME49720 offers superior audio signal amplification for outstanding audio performance. It combines extremely low voltage noise density (2.7nV/√Hz) with low THD+N (0.00003%), for use in demanding audio applications. This stable unit gain AOP achieves outstanding AC performance while generating complex loads with values up to 100pF.
Product typeOperational amplifier (AOP)
Amplification ClassAB
Number of channel2
Supply voltage range±2.5V à ±17V
Case/Connection typeDIP8
Output current26mA
Input noise density2.7nV/rtHz
THD+N0.00003%
Slew rate±20V/µs
Load impedance2kΩ
PSRR / CMRR> 120dB
Gain bandwidth55MHz
Open loop gain140dB @ RL = 600Ω
Min/Max operating temperature-40°C / 85°C
OPA TypeDual
4 reviews
Transparent along frequency spectrum
I've bought 6 to replace the stock OP AMPS on my two Fosi Audio V3 Mono.
Very good transparency with excelent bottom end and extended top end without any harshness.
This review has been posted for TI LME49720NA/NOPB Operational Amplifier OPA Class AB 2 Channel DIP8 (Unit)
Je suis d'accord les avis précédents. Bon aop bien équilibré. Mais le rendu manque un peu de corps; la musique semble "dégraissée". Avec une très bonne dynamique, presque trop.
Finalement, je ne recommande pas vraiment cet aop
Pas pour tous les systèmes...
AOP d'une grande franchise avec une dynamique très réactive quoique pas toujours bien contrôlée. Médium et aigu très piqués mais grave fortement atténué, comme gommé. Bonne image stéréo. Un AOP qui en aucun cas ne pourra atténuer la brillance d'une électronique ou d'une enceinte. A associer avec des enceintes douces et jugées trop "basseuses".
Volée de bois vert
Pas d'avis sur cet AOP ?
/ ! Si vous recherchez des basses lourdes et très profondes, passez clairement votre chemin.
La dimension, la fidélité et la justesse sonore qu'offre cet AOP est vraiment incroyable !
The Texas Instruments LME49720NA/NOPB is a high performance 2-channel Class AB, high performance operational amplifier (OPA) integrated in a DIP8...
