Step Shunt potentiometer Vishay Dale 23 positions Ø6mm Serrated Axis Stereo 50K LOG
Reference : 11616
29,90 €tax incl.
24,92 € tax excl.
This type of potentiometer is superior to the potentiometers with carbon track because the signal crosses only 2 metal resistors in series.
Wear is also much less important. It is especially advisable on the assemblies claiming the highest possible fidelity on low noise preamplifiers, solid-state headphone amplifiers with discrete component.
Main Features :
  • Shunt-type resistor switch potentiometer base.
  • 23 positions.
  • High quality metal resistors Vishay Dale.
  • Resistance 50K.
  • Overall diameter: 37mm.
  • Body Diameter: 29mm./ Li>
  • Off-axis length: 63mm.
  • Length of the axis: 10mm.
  • Diameter of the axis of the potentiometer: 6 mm.
  • Drilling diameter: 11 mm.
  • Weight: 43gr
  • Delivered: unit.
Schéma de branchement potentiomètre commuté shunt vishay dale 23 positions stéréo
