EXICON ECX10N20 Transistor MOSFET (2SK1058)
Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for audio amplifier design.
Reference : 15183
7,50 €tax incl.
6,25 € tax excl.
Exicon ECX10N20
Transistor MOSFET 2SK1058
Exicon ECX10N20 Transistor MOSFET (2SK1058)
Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for audio amplifier design. Their operating and thermal stability makes them extremely reliable and eliminates the need for a protection circuit. These advantages, combined with high bandwidth, low power requirements and easy paralleling, make it easy to build robust amplifiers with excellent sound characteristics.
The EXC10N20 is an excellent equivalent of the 2SK1058, with improved performance:
  • Specifically designed for audio amplification applications.
  • High thermal conductivity.
  • Excellent frequency characteristics.
  • Built-in protection diode.
  • No current concentration, for a high resistance to electrical destruction.
  • Thermal characteristics protecting against short circuits and thermal runaway.
  • Complementary to the EXC10P20 model
Product typeMOSFET
Number of pins3
PackageTO-247
maximum ratings (Tc = 25°C)
Drain-Source voltage (Vdss)200V
Gate-Source voltage (Vgss)+/-14V
Continuous drain current (Id)8A
Body drain diode current (Idr)8A
Allowable power dissipation * Tcase=25°C (Pd)125W
Channel temperature(Tch)150°C
Storage temperature range (Tstg)-55°C à 150°C
Electrical characteristics (TC = 25°C)
SymbolParametersTest conditionsMin.Typ.Max.
BVdsxDrain-Source breakdown voltageVgs = 10V
Id = 10mA
200V--
Vgs(off)Gate-Source cut-off voltageVds = 10V
Id = 100mA
0.15V-1.5V
Vds(sat)Drain-Source saturation voltageVgd = 0
Id = 8A
--10V
IdsxDrain-Source cut-off currentVgs = 10V
Vds = 200V
--10mA
Dynamic characteristics
CissInput capacitance--500pF-
CossOutput capacitanceVgs = 0-300pF-
CrssReverse transfer capacitancef = 1MHz-10pF-
TonTurn-on timeVds = 20V-100ns-
ToffTurn-off timeId = 7A-50ns-
2 reviews
replacement type
I used the ECX10N20 transistor as a replacement for the discontinued SK1058 transistor to fix a problem with our power amplifier in the KS SAT MKII PA system. It works perfectly without any circuit modifications.
Delivery was prompt.
Many thanks to Audiophonics. A reliable company.
Replacement type
This review has been posted for EXICON ECX10N20 Transistor MOSFET (2SK1058)
Un bon achat
Excellent MOSFET pour le Projet 101 Elliott Sound Products. Merci Audiophonics
Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion,...
