HIFIBERRY DAC2 PRO PCM5122 DAC Board for Raspberry Pi Burr Brown 24bit 192kHz
The HiFiBerry DAC2 Pro is a high resolution digital to analog and analog to digital converter, dedicated to be used in combination with a Raspberry Pi (A+, B+, 2B, 3B, 3B+, 4B+, Zero). It is a sound card for Raspberry Pi optimized to enjoy high quality audio playback at a low price.
Reference : 15642
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 28-05-2025.
HiFiBerry DAC2 Pro
HiFiBerry DAC2 Pro Module DAC pour Raspberry Pi Burr Brown 24bit 192kHz
It is based on a Burr Brown conversion chip supporting sampling rates up to 24bit 192kHz PCM. It also embeds a low jitter clock circuit and integrates a headphone amplifier.
The input is on a 40 pin GPIO header and the output is on stereo RCA (line) or via the amplified 3.5mm headphone output. There is also an additional analog output on a PCB connector. Another PCB connector allows to connect a DSP module to the DAC2 Pro.
1GPIO Input
2DSP Extension (DSP board not included)
3Analog output
4Line output
5Headphone output
Analog output connector (J1)
This connector can be used to connect an external module, such as an amplifier. This output is connected in parallel with the RCA output.
+5V12R
GND34GND
+5V56L
Product typePCM5122 DAC board
InputGPIO 40 pins
Outputs1x Stereo ligne RCA
1x Jack 3.5mm headphone output
1x Analog output (PCB connector)
CompatibilityRaspberry Pi A+, B+, 2B, 3B, 3B+, 4B+, Zero
Max output voltage2.1Vrms
SNR112dB
THD+N-93dB
Frequency response10Hz - 70kHz
Supported sampling ratesPCM up to 24bit 192kHz
Dimensions5.5 x 6.5 x 1cm
Weight20g
Consumption< 0.3W
Package1x Hifiberry DAC2 Pro Module
Nylon spacers / screws/td>
InputGPIO
OutputJack 3.5mm
OutputPCB Connector
DAC / ADC ChipPCM5122
Max sampling rate192kHz
The HiFiBerry DAC2 Pro is a high resolution digital to analog and analog to digital converter, dedicated to be used in combination with a Raspberry...
