IAN CANADA TRANSPORTPI Digital Interface SPDIF Low Jitter for Raspberry Pi
Ian Canada's TransportPi is a low jitter digital audio interface in Raspberry Pi HAT format. The module is therefore input on a 40-pin GPIO connector. The module offers a complete panel of outputs with isolated Coaxial S/PDIF, Optical S/PDIF and BNC, as well as an I2S LVDS output on HDMI and a GPIO output.
Reference : 14232
105,00 €tax incl.
87,50 € tax excl.
This product has been replaced by the new version, the digital interface IAN CANADA TRANSPORTPI MKII.
Ian Canada TransportPi
Ian Canada TransportPi Interface Numérique Low Jitter SPDIF pour Raspberry Pi
Its architecture allows it to work perfectly with the FifoPi reclocker module or any other FiFo module, in order to improve the sound quality of the module by reducing the jitter generated as much as possible. As TransportPi does not directly integrate a clock, it is imperative to associate it with a clock module (such as FiFoPi for example).
The integration of this module with a Raspberry Pi, a FifoPi module and an adapted reading software solution therefore allows the design of a complete high-quality audiophile reader/interface.
The TransportPi module is not stand-alone (does not work alone).
HDMI Connector pinout
Ian Canada TransportPi Interface Numérique SPDIF Low Jitter pour Raspberry Pi
GPIO Pinout
N° PinJ2
40 pins GPIO connector to board below
(Normally Raspberry Pi)
J1
40 pins GPIO connector to HAT on top
(FifoPi or DAC or other audio board)
1
17
3.3V from preceding board3.3V from preceding board
2
4
5V from preceding board5V from preceding board
6
9
14
20
25
30
34
39
GNDGND
12SCK InputSCK Path Through
35LRCK/DL InputLRCK/DL Path Through
40SD/DR InputSD/DR Path Through
3I2C DAI2C DA
5I2C CLI2C CL
8TXD0TXD0
10RXD0RXD0
Tous les autres pinsSame pin from preceding boardSame pin from preceding board
Product typeDigital audio interface
Input1x GPIO
Outputs1x GPIO
1x I2S LVDS via HDMI
1x S/PDIF Optical Toslink
1x S/PDIF Coaxial
Supported sampling ratesOptical, Coaxial : up to 192kHz
I2S via HDMI : up to 768kHz
Dimensions65 x 56.5mm
InputGPIO
OutputGPIO
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S LVDS via HDMI
DAC / ADC ChipNC
Max sampling rate768kHz
Ian Canada's TransportPi is a low jitter digital audio interface in Raspberry Pi HAT format. The module is therefore input on a 40-pin GPIO...
