Bluetooth 5.0 24bit 192kHz
This DAC and ADC module at a small price shows its versatility by proposing a complete connectivity. It offers Jack 3.5mm, coaxial, optical Toslink and an analog input on PH2.0 connector. We find the same connectivity at the output except for the Jack 3.5mm, but with a stereo RCA output. This connectivity is completed by a Bluetooth 5.0 reception and transmission capacity, so it is possible to broadcast music to the module from a smartphone or a tablet for example, but also to transmit the signal from the module to headphones or Bluetooth speakers. Practical, this function greatly limits the use of cables in a modern audio installation.
Product type | DAC / ADC board |
Inputs | Bluetooth 5.0 1* Jack 3.5mm 1* Coaxial 1* Optical Toslink 1* PH2.0 analog input |
Outputs | Bluetooth 5.0 1* Stereo RCA 1* Coaxial 1* Optical Toslink 1* PH2.0 analog output |
Supported sampling rates | PCM up to 24bit 192kHz |
Power supply | 5VDC via USB-C or solder pads (power supply sold separately) |
PCB dimensions | 130*37mm |
Mounting holes spacing | 124*31mm |
Input | Jack 3.5mm |
Input | Optical |
Input | PCB Connector |
Input | SPDIF |
Input | Bluetooth |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Output | PCB Connector |
Output | RCA |
Output | Bluetooth |
DAC / ADC Chip | NC |
Max sampling rate | 192kHz |
