DAC Board ES9018K2M I2S 32bit 384kHz DSD256
10%
This small DAC module is ideal for integration in a DIY audio project. It will allow you to convert an I2S signal to input and then output to stereo RCA or 3.5mm jack. The digital/analog conversion is done thanks to an ESS ES9018K2M chip, offering good performances for a precise sound restitution. It also allows the support of high resolution streams, up to PCM 32bit 384kHz and DSD256.
Reduced price!
Reference : 16687
Limited time offer:
24,90 €tax incl.
-10%
22,41 €tax incl.
18,68 € tax excl.
Last items in stock !
Shipping date: 04-07-2025.
DAC Board
ESS9018K2M I2S 32bit 384kHz DSD256
Module DAC ESS9018K2M I2S 32bit 384kHz DSD256
I2S connection :
I2S Cable
Product typeDAC board
DAC chipESS ES9018K2M
InputI2S
Outputs1x Stereo RCA
1x Jack 3.5mm
DSD up to DSD256
Supply voltage9-25VDC via Jack DC or 7-18VAC on screw terminal
Dimensions72.5 x 71.5 x 29.3mm
InputI2S
OutputJack 3.5mm
DAC / ADC ChipES9018K2M
Max sampling rateDSD256
Max sampling rate384kHz
This small DAC module is ideal for integration in a DIY audio project. It will allow you to convert an I2S signal to input and then output to...
