ESS9018K2M I2S 32bit 384kHz DSD256
This small DAC module is ideal for integration in a DIY audio project. It will allow you to convert an I2S signal to input and then output to stereo RCA or 3.5mm jack. The digital/analog conversion is done thanks to an ESS ES9018K2M chip, offering good performances for a precise sound restitution. It also allows the support of high resolution streams, up to PCM 32bit 384kHz and DSD256.
I2S connection :
| Specifications | |
| Product type | DAC board |
| DAC chip | ESS ES9018K2M |
| Input | I2S |
| Outputs | 1x Stereo RCA 1x Jack 3.5mm |
| Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 |
| General | |
| Supply voltage | 9-25VDC via Jack DC or 7-18VAC on screw terminal |
| Dimensions | 72.5 x 71.5 x 29.3mm |
| Input | I2S |
| Output | Jack 3.5mm |
| Output | RCA |
| DAC / ADC Chip | ES9018K2M |
| Max sampling rate | 384kHz |
| Max sampling rate | DSD256 |
