DAC Module MS8413
This small, affordable DAC module is equipped with an MS8413 digital-to-analog conversion chip and supports PCM audio streams up to 24bit 192kHz. On the input side, the module features a coaxial jack and a Toslink optical port. Output can be either RCA or 3.5mm jack.
Reference : 18641
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 07-04-2026.
DAC Module MS8413 SPDIF Coaxial Optical 24bit 192kHz
DAC module MS8413
MS8413 DAC module connection diagram
1USB-C power input
2Coaxial input
3Optical input
4Jack 3.5mm line output
5AUX RCA output
Product typeDAC board
DAC chipMS8413
Inputs1x Optical Toslink
1x Coaxial
Outputs1x Jack 3.5mm line output
1x AUX stereo RCA output
Supported sampling ratesPCM up to 24bit 192kHz
Distorsion0.001%
Supply voltage5VDC via USB-C (power supply not included)
PCB dimensions61 x 57mm
Total dimensions61 x 76mm
OutputJack 3.5mm
DAC / ADC ChipMS8413
Max sampling rate192kHz
I love it
an excellent value for money small module with outstanding sound. it can even drive a Hifiman HE400se with pleasant dynamics, albeit relatively quietly :)
This review has been posted for DAC Module MS8413 SPDIF Coaxial Optical 24bit 192kHz
This small, affordable DAC module is equipped with an MS8413 digital-to-analog conversion chip and supports PCM audio streams up to 24bit 192kHz....
