EVERSOLO DAC-Z8 DAC ES9038Pro XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
EverSolo's DAC-Z8 is a high-end DAC that is extremely powerful. It embeds high-end components with notably an ESS ES9038Pro digital/analog conversion chip and a XMOS XU316 USB interface allowing it to support high-resolution audio streams and to provide a clear and detailed sound reproduction. The DAC-Z8 also offers a wide range of features that make it a versatile and efficient device.
Reference : 17132
699,00 €tax incl.
582,50 € tax excl.
Last items in stock !
Shipping date: 02-09-2025.
EverSolo DAC-Z8
EverSolo DAC-Z8 DAC ES9038Pro XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
ES9038Pro DAC
The heart of the DAC-Z8, its digital-to-analog conversion stage, is equipped with an excellent ESS ES9038Pro chip. This ensures low distortion and noise for a truly convincing high-fidelity music experience. In addition, the DAC-Z8's audio circuitry is specifically calibrated to deliver its full potential.
XMOS XU316 USB Interface
The USB input of the DAC-Z8 is combined with an XMOS XU316 interface, which is able to process audio data quickly and efficiently for optimal signal transmission. This chip also supports high-resolution streams up to PCM 32bit 768kHz and DSD512 Native, as well as MQA files.
MQA Decoder
The EverSolo DAC-Z8 supports the decoding of MQA (Master Quality Authenticated) files from its USB, Toslink optical and coaxial inputs. This format allows to enjoy a sound quality as close as possible to the original studio recording.
High precision clocks
The DAC-Z8 is equipped with two very high precision clocks on the frequencies 45.1584MHz and 49.152MHz. These allow you to enjoy a high quality decoding, ensuring a very low jitter for a detailed and precise sound..
Optimized I/V circuit
The I/V circuit of the DAC-Z8 consists of 8 OPA1612 OPAs. It uses multi-channel signal shunting compensation technology, with the 8 OPAs corresponding to the 8 output channels of the I/V conversion stage, ultimately providing a two-channel parallel output. In addition to the high-precision resistors, this circuitry assists in the lossless amplification of the XLR, RCA and headphone outputs, improving channel separation, dynamic range and sonic integrity.
Amplifier circuit & Balanced preamp output
The DAC-Z8's analog audio circuitry is fully balanced. The XLR, RCA and headphone outputs are all processed by a balanced differential amplifier circuit for low noise and improved channel separation. The high-fidelity preamplifier circuitry provides precise and efficient volume control.
Bluetooth 5.0
In addition to a complete connectivity, the DAC-Z8 has a Bluetooth 5.0 Qualcomm QCC5125 receiver, which allows you to broadcast your music remotely, from a smartphone or a tablet for example, while supporting the codecs of high-resolution transmission aptX HD and LDAC for a high quality restitution in wireless.
Digital filters
The EverSolo DAC-Z8 offers no less than 7 PCM filters and 4 DSD filters. These allow you to adapt the sound reproduction of the device according to your listening preferences and your audio system.
Low ripple power supply stage
A low-noise power supply stage and capacitor filter have been specifically designed for the DAC-Z8. They provide a clean, interference-free electrical signal to all of the unit's audio circuits for rich, accurate sound reproduction.
A powerful headphone amplifier
The DAC-Z8's headphone amplifier also performs very well and is capable of providing comfortable power to accompany headphones with impedance from 16 to 300Ω without difficulty. This one also has a two-step gain control to accommodate both demanding headphones and more sensitive earphones.
Control app
The DAC-Z8 can be controlled via the free EverSolo Control App available on Android and iOS. The latter allows access to the vast majority of the parameters available on the device.
Color Screen & Intuitive Interface
The front panel of the DAC-Z8 features a beautiful 3" color LCD screen. This one displays an ergonomic and intuitive interface allowing you to access all the functions and parameters of the DAC.
Multi-function button
The DAC's multi-function knob can be used to control volume level, navigate menus, select a source or output, change filters, change the display, and more. It allows full control of the device in a convenient way.
Aluminum frame
The EverSolo DAC-Z8 is dressed in a beautiful, sturdy aluminum chassis that has been precision-machined by CNC (numerical control). It offers a modern and sober design, allowing it to be easily integrated into any audio system.
Test du Eversolo DAC-Z8 par Audio Science Review (Amir)
" Wish you could see my face smiling as I type this, reflecting my experience with the DAC-Z8. Not only does it have superb performance but it is a delight to see and use. The brand jumps into a very crowded and competitive market and easily makes room for itself with state of the art performance and delightful user interface. "
Product typeDAC
InputsBluetooth 5.0
1* USB-B
1* USB-C
1* Optical Toslink
1* Coaxial
Outputs1* Balanced stereo XLR
1* Single-ended stereo RCA
1* Jack 6.35mm headphone output
DAC chipES9038Pro
USB interfaceXMOS XU316
OPA10* OPA1612
Bluetooth receiverQualcomm QCC5125
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA
Optical / Coaxial : PCM upto 24bit 192kHz, DSD DoP up to DSD64, MQA
Supported Bluetooth codecsSBC
AAC
aptX
aptX LL
aptX HD
LDAC
ScreenLCD 3"
Control app
Recommended headphone impedance16-300Ω
XLR output performances
Output level4.1Vrms @ 0dBFS
THD+N (A-Weighted)0.000062% @ 1kHz (-124dB @ 1kHz)
THD+N (No-Weighted)0.000069% @ 1kHz (-123dB @ 1kHz)
Noise (No-Weighted)< 1.2µVrms
SNR (No-Weighted)133dB @ 1kHz
Frequency response20Hz-20kHz (±0.1dB)
Crosstalk-130dB @ 1kHz
DNR (No-Weighted)133dB @ 1kHz
RCA output performances
Output level2.3Vrms @ 0dBFS
THD+N (A-Weighted)0.000086% @ 1kHz (-121dB @ 1kHz)
THD+N (No-Weighted)0.000097% @ 1kHz (-120dB @ 1kHz)
Dynamic range (No-Weighted)133dB @ 1kHz
Headphone output performances (Low gain mode)
Output level1.2Vrms @ 0dBFS
Output power45mW @ 32Ω
THD+N (A-Weighted)0.00015% @ 1kHz (-116dB @ 1kHz)
THD+N (No-Weighted)0.00018% @ 1kHz (-115dB @ 1kHz)
Noise (No-Weighted)< 2µVrms
SNR (No-Weighted)124dB @ 1kHz
Dynamic range (No-Weighted)119dB @ 1kHz
Headphone output performances (High gain mode)
Output level2.8Vrms @ 0dBFS
Output power26mW @ 300Ω
THD+N (A-Weighted)0.00016% @ 1kHz (-116dB @ 1kHz)
Dynamic range (No-Weighted)124dB @ 1kHz
Supply voltage110~240VAC 50/60Hz
Consumption9W
Dimensions (L*P*H)270*187*50mm
Package1* EverSolo DAC-Z8
1* Remote control
1* Power cable
1* USB cable
OutputJack 6.35mm
DAC / ADC ChipES9038PRO
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
5 reviews
exceptionnel
après avoir demander conseil a mr david hubert entre gustard x18 et le model eversolo z8 je n'ai pas hésité une seconde j'avoue qui'l est très beau bien construit j'ai télécharger la derriere mise a jours pour le vumètre vintage l'effet et superbe un beau BB j'ai pris également AUDIRVANA un Régal un son d'une qualité irréprochable très aéré pour moi il est parfait d'une richesse en detail incroyable pour le tarif franchement allez y encore merci a vous
This review has been posted for EVERSOLO DAC-Z8 DAC ES9038Pro XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
Excellent dac
Je me suis fié aux avis et je ne suis vraiment pas déçu.
Superbe qualité de fabrication, UI fluide et ergonomique et qualité sonore top niveau en sortie de carton.
Un vrai plaisir à l'écoute, très détaillé sans être analytique, soundstage très large et chaque instrument est à sa place. Couplé à un ampli Pathos Aurium c'est vraiment du bonheur!
J'ai failli prendre un Gustard A26 mais je ne pense pas que j'aurais eu plus de plaisir pour presque le double du prix.
Bravo à Eversolo et à Audiophonics toujours aussi sérieux.
Excellent produit
Qualité de finition irréprochable. Le produit est solide, bien construit et bien fini. La navigation dans les menus est intuitive.
La qualité sonore est quant à elle vraiment top. C'est précis, détaillé, dynamique mais cela relativement transparent. Un excellent produit que je recommande (associé avec un WIIM pro).
Trop top !
Excellent rapport qualité prix. Toutes les fonctions sont là et les performances sont audibles.
Design chinois, peut-être mais le résultat est au meilleur niveau et représente une sacré concurrence à des marques haut de gamme
Ravi de mon achat
Je le garde !
Je le garde !
Voici un DAC performant, musical, au look sobre et une utilisation bien meilleure que le HifiRose revendu pour cause d'ergonomie détestable.
Le Z8 ne fait pas lecteur de réseau contrairement au Rose. Pas grave, je passe par mon PC.
Le Z8 a une excellente entrée USB couplé au volume, contrairement au Rose qui reste à fond (bêtise !!!)
Le Z8 à une appli android. Très pratique.
A noter la réactivité d'EVERSO aux suggestions : http://forum.zidoo.tv/index.php?threads/wishes-z8-suggestions-souhaits-dam%C3%A9lioration.95035/
EverSolo's DAC-Z8 is a high-end DAC that is extremely powerful. It embeds high-end components with notably an ESS ES9038Pro digital/analog...
