FERRUM WANDLA DAC ES9038PRO Balanced I2S HDMI ARC 32bit 768kHz DSD256 MQA
Ferrum offers with its WANDLA a versatile and extremely efficient DAC, capable of very high quality digital/analog conversion for the most precise and faithful sound reproduction.
By buying this product you get 279 loyalty points
Reference : 17659
2 795,00 €tax incl.
2 329,17 € tax excl.
Shipping date: 20-05-2025.
FERRUM WANDLA
FERRUM WANDLA DAC ES9038PRO I2S ARC 32bit 768kHz DSD256 MQA Noir
ES9038Pro
At the heart of this WANDLA, a digital/analog conversion stage using an ESS ES9038Pro chip, recognized for its incredible performance and its ability to provide precise and transparent particular sound reproduction. The chip here has an independent power supply allowing it to reveal its full potential.
SERCE
Regarding the digital audio system module, the optimized ARM chip offers the shortest possible signal path, which makes 5 chips redundant. Includes MQA decoder/renderer and a selection of digital filters.
WANDLA offers three ESS digital filters and two digital filters created for Ferrum by renowned filter manufacturer HQ Player.
I/V conversion and proprietary amplification system
The Wandla embeds an I/V converter. These offer excellent measurements with an extremely low level of distortion and noise.
In addition, it has a fully balanced, precision-tuned modified preamplifier IC.
Optimized digital inputs and a balanced signal
The Wandla has many entrances; Specially programmed USB, coaxial and optical S/PDIF ports, HDMI ARC (TV) and I2S optimized for audio. In addition, the balanced design ensures clean sound on the stereo RCA output and a truly balanced stereo XRL output.
Ferrum Power Link Technique (FPL)
Unique design of an FPL power socket: two wires providing power and two wires providing feedback to ensure flat voltage at all times. This eliminates the adverse effects of cable resistance by effectively improving transient response. The speed of current delivery to the input of the powered device is significantly improved.
Designed for HYPSOS
WANDLA comes with a carefully selected DC power adapter. However, to get the most out of WANDLA, you can connect it to HYPSOS using the proprietary Ferrum Power Link DC power cable (not included).
MQA
MQA (for Master Quality Authenticated) is an award-winning British technology for restoring the sound of the original recording. The MQA Master file is authenticated by the artists, producers or rights holders. These files are small enough to be streamed or downloaded. The Wandla includes an MQA decoder to play these files in order to offer the best possible audio quality.
Technical Charateristics
Prodeuct typeDAC
Digital inputs1* USB-C
1* Optical Toslink
1* Coaxial
1* AES/EBU
1* HDMI ARC (TV with CEC)
1* I2S
Analog inputsRCA 47kΩ (Vmax : 9,5V RMS / 2 – 3,5V RMS recommended)
Ouputs1x RCA stereo unbalanced
1x XLR stéréo balanced
DAC ChipESS ES9038Pro
Supported sample ratesUSB: PCM 32bit 768kHz, DSD512, DSD DoP up to DSD256, MQA
I2S: PCM 32bit 768kHz, DSD512, DSD DoP up to  DSD512, MQA (PS AUDIO compatible)
HDMI ARC: PCM 24bit 192kHz, MQA, TV with CEC
AES/EBU: PCM 24bit 196kHz, DSD DoP up to  DSD64, MQA
Coaxial, Optical: PCM 24bit 192kHz, DSD DoP up to DSD64, MQA
Frequency response10Hz – 200kHz +/- 0,1dB
Output levelRCA : 4,65V RMS unbalanced @0dBFS
XLR : 9,3V RMS balanced @0dBFS
CAD THD-121dB (0,00009%); THD+N : -115dB (unweighted)
THD analog input-123dB @ Output level 2V RMS
Dyn.Analog : 127dB (A-weighted)
Digital : 127dB (A-weighted)
Crosstalk-120dB for  1kHz, better than -100dB for 20Hz
-20KHz
Output impedenceUnbalanced : 22Ω
Balanced : 44Ω
Volume controlAnalog with bypass option / Digital with DAC operation only
Power consumptionIdle : 10W
Max : 15W
Power imputs5.5/2.5mm DC connector centre positive
Proprietary FPL (FPL) 4-pin DC connector
22-30VCC
Power adaptator100-240 VCA to 24VCC
Dimensions271*206*50mm
Weight1.8Kg
Package1x Ferrum WANDLA DAC
1x Power cable
1x Remote control
InputAES/EBU
InputI2S via HDMI
InputHDMI ARC
DAC / ADC ChipES9038PRO
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
Remote ControlYes
Ferrum offers with its WANDLA a versatile and extremely efficient DAC, capable of very high quality digital/analog conversion for the most precise...
