FIIO K7 DAC Headphone Amplifier 2x AK4493S THX AAA-788+ 32bit 384kHz DSD256
FiiO's K7 is a high performance desktop DAC and Headphone Amplifier combo, demonstrating an exemplary design for an audio reproduction marked by great transparency, richness and precision.
Reference : 18017
219,00 €tax incl.
182,50 € tax excl.
Shipping date: 10-07-2025.
FIIO K7
DAC 2x AK4493S Headphone Amplifier THX AAA-788+ 32bit 384kHz DSD256
High-end balanced amplification
The K7 uses the same THX AAA 788+ amplifier as the K9 Pro. It is capable of outputting up to 560mW at 300Ω for only 1% distortion and up to 2000mW at 32Ω for only 1% distortion.
FIIO K7 BT DAC 2x AK4493S Amplificateur Casque THX AAA-788+ 32bit 768kHz DSD512 Bluetooth 5.1 LDAC AptX HD
Dual DAC
Each channel is equipped with its own DAC chip AK4493SEQ producing a rich and delicate sound with a pleasant timbre.
Advanced decoding capabilities
The XMOS XUF208 chip uses a dual clock management system to handle a multitude of different audio formats.
A real personality
The K7's massive, beautifully integrated metal knob on the front panel provides comfortable control of the volume level. The circular LED indicator surrounding this volume knob lights up in different colors depending on the sample rate of the file being played, while complementing the sobriety of the case with a touch of color.
  • Blue light : 48kHz and below
  • Yellow light : Above 48kHz
  • Green light : DSD
Smart protection systems
Your K7 is protected from overheating, overloading and also has DC power protection to ensure the best listening experience over the long term.
Many possibilities thanks to a complete connectivity
1Source indicator
2Jack 6.35mm Output
3Source selection
4Gain
5Output selection
6Volume/selection button
7Jack 4.4mm Balanced Output
8Stereo RCA input
9Pre-out RCA output
10Coaxial input
11Optical Toslink input
12USB-B input
13DC 12V load
Volume control and gain adjustment
The adjustment of the gain level is done simply thanks to a switch on the front panel of the K7. For the gain, the device offers 2 settings. This setting allows the K7 to be used with a large majority of headphones and earphones on the market for a comfortable volume listening. Concerning the volume, the K7 has 112 adjustable steps thanks to the knob on its front panel.
Volume control on ADC
The K7 incorporates an ADC, allowing it to take advantage of an RCA line input with adjustable volume level. It reconstructs the analog volume curve to allow for smooth and accurate adjustment while eliminating unwanted noise and potential balance problems. This design also allows many different headphone models with different sensitivities to be used with the K7.
SpEcifications
Product typeDAC
Headphone amplifier
DAC chips2x AK4493SEQ
USB InterfaceXMOS XUF208
Inputs1x USB-B
1x Coaxial SPDIF
1x Optical Toslink
1x Stereo RCA line input
Outputs1x Stereo RCA line output
1x 4.4mm balanced headphone output
1x 6.35mm headphone output
Supported sampling ratesPCM 32bit 384kHz
DSD256
AmplificationTHX AAA 788+ Amp
Adjustable gain
Recommended headphone impedance16-300Ω
Headphone output powerL+R 2000mW + 2000mW (32Ω, balanced headphone output, THD+N < 1%)
L+R 1220mW + 1220mW (32Ω, unbalanced output, THD+N < 1%)
SNRPO ≥ 123dB (A-weighted, UAC)
Balanced output ≥ 120 db (A-weighted, UAC)
Background noisePO < 4.4 uV (A-weighted, UAC)
Balanced output < 7.7 uV (A-weighted, UAC)
Output impedance< 1 Ohm (32 Ohm load)
Dimensions120 x 168 x 55mm
Weight620g
Package1x FiiO K7
1x Power supply
1x USB-B to USB-A cable
1x Jack 3.5mm to Jack 6.35mm adapter
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipAK4493S
Max sampling rate384kHz
Max sampling rateDSD256
An excellent dac-amp at this price
I use the Fiio K7 with Hifiman HE400se headphones and it drives them well (I usually listen with the volume on low gain and the knob between 1 and 3 o'clock). The volume control is done in the analogue domain, so changing it has no effect on the signal quality. Some people remark on a lag between turning the volume knob and the volume actually changing, but this has not been a problem at all. I especially notice the soundstage (instruments are easy to locate when listening) and the ability to reproduce a large dynamic range cleanly. I listen mostly using Roon upsampled to the dac's limit (on USB, 384kHz-32bit/DSD256), so adjusting the dac filters isn't really necessary, still it would be nice to be able to fiddle. Very happy with the purchase.
This review has been posted for FIIO K7 DAC Headphone Amplifier 2x AK4493S THX AAA-788+ 32bit 384kHz DSD256
FiiO's K7 is a high performance  desktop DAC and Headphone Amplifier combo , demonstrating an exemplary design for an audio...
