FOSI AUDIO DAC-Q4 DAC PCM5100 Headphone Amplifier MAX97220 24bit 192kHz
Compact, versatile and particularly affordable, the Fosi Audio DAC-Q4 brilliantly combines the functions of DAC and headphone amplifier. Ideal for a desktop installation, it will fit equally well into a more conventional audio system. Its digital/analog conversion stage is based on a Texas Instruments PCM5100 DAC chip, ensuring quality decoding for precise sound reproduction.
Reference : 17959
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 16-12-2025.
Fosi Audio DAC-Q4
Fosi Audio DAC-Q4 DAC PCM5100 Amplificateur Casque MAX97220 24bit 192kHz
Compact, versatile and particularly affordable, the Fosi Audio DAC-Q4 brilliantly combines the functions of DAC and headphone amplifier. Ideal for a desktop installation, it will fit equally well into a more conventional audio system. Its digital/analog conversion stage is based on a Texas Instruments PCM5100 DAC chip, ensuring quality decoding for precise sound reproduction. It is accompanied by an MS8416 SPDIF receiver supporting PCM streams up to 24bit 192kHz, and a CT7601 USB interface accepting PCM signals up to 24bit 96kHz. The headphone amplification stage of the Fosi Audio DAC-Q4 is entrusted to a MAX97220 chip capable of developing a power of 100mW at 32Ω. On the connectivity side, inputs include USB-B, optical and coaxial. Output is either RCA, or on the amplified headphone output with Jack 3.5mm connector. Finally, in addition to volume control, the front panel features a tone control for adjusting bass and treble levels.
1Input selector
2Jack 3.5mm headphone output
3Bass gain control
4Treble gain control
5Power LED
6ON-OFF Switch / Volume knob
75VDC power input
8RCA output
9Coaxial input
10Optical input
11USB-B input
Product typeDAC
Inputs1* USB-B
1* Optical Toslink
1* Coaxial
Outputs1* Stereo RCA
1* Jack 3.5mm headphone output
Supported sampling ratesUSB : PCM up to 24bit 96kHz
Optical / Coaxial : PCM up to 24bit 192kHz
Frequency response20Hz-20kHz
USB CompatibilityWindows XP / 7 / 8 / 10
Mac
Linux
Distortion0.01%
SNR≥ 105dB
Max headphone output power100mW @ 32Ω
Recommended headphone impedance16-200Ω
RCA output level2.3V
Supply voltage5VDC
Dimensions73.5*98*33mm
Housing materialAluminum alloy
Package1* Fosi Audio DAC-Q4
1* USB power cable
1* USB cable
1* Optical cable
OutputJack 3.5mm
DAC / ADC ChipPCM5100
Max sampling rate192kHz
ClassN/A
Polyvalent mais...
Attelé à un lecteur CD - DVD - Blue Ray etc... de chez Sony qui ne dispose pas de sortie audio il permet soit l'écoute au casque soit d'envoyer un signal analogique sur un ampli audio. Tout ça fonctionne mais l'écoute au casque avec les correcteurs de tonalité en position "neutre" - " à 12 h " manque de graves. Précisons que le même casque donne toute satisfaction par ailleurs et d'un autre côté que s'il y a des corrections de tonalité sur le DAC autant s'en servir...
This review has been posted for FOSI AUDIO DAC-Q4 DAC PCM5100 Headphone Amplifier MAX97220 24bit 192kHz
Compact, versatile and particularly affordable, the Fosi Audio DAC-Q4 brilliantly combines the functions of DAC and headphone amplifier. Ideal for...
