FX-AUDIO DAC-M1 DAC ES9038Q2M XMOS 32bit 768kHz DS512 Bluetooth 5.0 Gray
FX-Audio's DAC-M1 is a compact, affordable and powerful digital-to-analog converter. It is based on the use of an ESS ES9038Q2M DAC chip, associated with an XMOS XU208 USB interface, allowing for the support of high-resolution audio streams, up to PCM 32bit 768kHz and DSD512, while offering great sound transparency.
Reference : 15437
179,00 €tax incl.
149,17 € tax excl.
Last items in stock !
Shipping date: 08-05-2025.
FX-Audio DAC-M1
DAC ES9038Q2M XMOS 32bit 768kHz DSD512 Gray
FX-Audio DAC-M1 DAC ES9038Q2M XMOS 32bit 768kHz DSD512 Gray
FX-Audio's DAC-M1 is a compact, affordable and powerful digital-to-analog converter. It is based on the use of an ESS ES9038Q2M DAC chip, associated with an XMOS XU208 USB interface, allowing for the support of high-resolution audio streams, up to PCM 32bit 768kHz and DSD512, while offering great sound transparency. The DAC-M1 is also equipped with a headphone amplifier stage, based on a Texas Instruments TPA6120A2 chip. In terms of connectivity, the DAC-M1 is versatile, with USB-C, Coaxial, Optical and Bluetooth 5.0 inputs, using a Qualcomm CSR8675 receiver chip and supporting the aptX, aptX HD and aptX LL transmission codecs. For its outputs, the DAC-M1 offers a stereo RCA output, as well as a headphone output on the front panel on 6.35mm jack.
Test of FX-AUDIO DAC-M1 by Audio Science Review
"It is easy to see that the company has aimed high with this combination DAC and headphone high. The transparency is provided almost across the board with plenty of power to drive a range of headphones. It is nice to have different options in this class of product. "
Test du Loxjie A30 par Audio Science Review
Product typeDAC
DAC ChipES9038Q2M
USB InterfaceXMOS XU208
Headphone amplifier chipTPA6120A2
Bluetooth reception chipCSR8675
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Bluetooth 5.0
Outputs1x Stereo RCA
1x Jack 6.35mm headphone output
THD+N0.00025%
SNR118dB
USB Transmission modeAsynchronous
USB CompatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX 10.6
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Bluetooth : PCM up to 24bit 96kHz
Headphone output power500mW @ 32Ω
340mW @ 64Ω
180mW @ 150Ω
96mW @ 300Ω
Consumption3.5W
Standby consumption0.25W
Dimensions130 x 10 x 55mm
Weight350g
ColorGray
Package1x FX-Audio DAC-M1
1x Power adapter 12V 1A
1x Bluetooth antenna
1x Remote control
OutputJack 6.35mm
DAC / ADC ChipES9038Q2M
Max sampling rateDSD512
Max sampling rate768kHz
ColorGray
Remote ControlYes
parti pour un loxjie et je me retrouve avec ce FX audio
Très bon DAC, j'adore la commutation automatique entre le casque et les enceintes, il suffit de débrancher le casque et il bascule automatiquement sur les enceintes, le volume est propre à chaque mode. cela marche plutôt pas mal avec mon PC, Je l'ai relié en optique au pc et en rca à mon ampli enceintes, le son est bon pour un prix correct. Merci audiophonics.
This review has been posted for FX-AUDIO DAC-M1 DAC ES9038Q2M XMOS 32bit 768kHz DS512 Bluetooth 5.0 Gray
FX-Audio's DAC-M1 is a compact, affordable and powerful digital-to-analog converter. It is based on the use of an ESS ES9038Q2M DAC chip,...
