J'adore. Très bon son.
Je l'utilise avec des Quad ESL 57 et j'en suis totalement satisfait.
Seul l'afficheur fait un peu bas de gamme.
USB DAC ES9038Q2M XMOS U208 32bit 384kHz DSD256 Black
With its DAC-SQ3, FX-Audio offers a small, compact, affordable and powerful DAC. Featuring an ESS ES9038Q2M digital-to-analog conversion chip, it offers accurate playback and supports high sampling rates, up to 32bit 384kHz PCM and DSD256.
All of its circuitry has also been optimized, including an excellent XMOS XU208 USB interface and a low noise and ripple power stage.
On the connectic side, the input and the power supply are done via USB-B. For the outputs, the DAC-SQ3 provides stereo RCA, Coaxial and Optical Toslink.
The volume acts only on the RCA output.
The optical and coaxial outputs are fixed.
" Nice to see performance is maintained here while providing above average feature set as far as remote and volume control. "
| Specifications | |
| Product type | DAC |
| DAC Chip | ESS ES9038Q2M |
| Input | 1x USB-B |
| Outputs | 1x Stereo RCA 1x Optical Toslink 1x Coaxial |
| USB Interface | XMOS XU208 |
| THD+N | 0.00026% |
| SNR | 115dB |
| USB Transmission mode | Asynchronous |
| Supported sampling rates | USB : PCM up to 32bit 384kHz, DSD up to DSD256 Optical, Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
| Output impedance | 100Ω |
| OS Compatibility | Windows 7 / 8 / 8.1 / 10 Mac OSX 10.6 or later Linux |
| gENERAL | |
| Dimensions | 98 x 122 x 33mm |
| Consumption | 2.5W |
| Standby consumption | 0.05W |
| Housing material | Aluminum |
| Color | Black |
| Package | 1x FX-Audio DAC-SQ3 1x Remote control 1x USB Cable |
| Input | USB |
| Output | Optical Toslink |
| Output | Coaxial SPDIF |
| Output | RCA |
| DAC / ADC Chip | ES9038Q2M |
| Max sampling rate | 384kHz |
| Max sampling rate | DSD256 |
| Color | Black |
| Networking | No |
| Remote Control | Yes |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Lefebvre F.
Yves C.
