By buying this product you get 124 loyalty points
Gustard has updated its product in X26 PRO version, available here : GUSTARD X26 PRO Balanced DAC.
Balanced DAC 2x ES9038Pro GPLL-M1 32Bit 768kHz DSD512 Noir
The Gustard X26 is a high-end DAC that is both versatile and delivers excellent audio performance thanks to its uncompromising design. Using only high-end audio components, this converter is optimized to deliver rich, accurate, dynamic sound that is as close as possible to the original signal.
Since the Gustard X26 uses a recent USB ESS interface, the DAC is not yet compatible with Open Source playback solutions such as Volumio or Daphile.
At the heart of the X26, two DAC ESS ES9038Pro chips are used for digital-to-analog conversion. Each channel has its own conversion chip and power supply to provide the best possible audio performance. These chips also support high sampling rates, ranging from the Gustard X26 to PCM 32bit 768kHz and DSD512 on USB and I2S inputs.
These chips are accompanied by an LPF Class A with only discrete components, specifically optimized for the DAC ES9038Pro.
The X26's main PCB is topped by a high-precision phase-locked loop module offering extremely low residual phase noise and an ultra-low clock signal jitter. Thanks to a complex algorithm, the jitter removal performance of the X26 is excellent.
The Master Clock of the DAC ES9038Pro is also provided by the GPLL module, operating synchronously to bypass internal ASRC resampling.
Logical functions are assigned to a CPLD, including a clock management system, a second PLL digital processing, DoP decoding and many other functions that play an important role in the X26's performance.
The Gustard X26 offers several digital filters, PCM and DSD, to adapt the sound reproduction to your listening and audio system, while reducing residual noise.
In order to offer high quality filters, Gustard has chosen to develop its own filters using a DSP Analog Device SHARC chip. This solution incorporates an anti-aliasing algorithm designed by Gustard, using a high-precision 64bit floating point system. In addition, this algorithm has been optimized to work perfectly with the ESS DACs and ensure the best possible sound quality.
The power supply of the X26 uses two toroidal transformers, a discrete hybrid I/V conversion circuit composed of 8 channels. This makes it possible to provide the entire system with a consistent, extremely clean and stable power supply, which is essential for high-quality sound reproduction.
In addition, each channel of the X26's analog circuit uses an independent power rail to limit interference and noise.
The Gustard X26 benefits from a complete connectivity capable of adapting to many audio systems. It includes USB-B, I2S LVDS on HDMI, Coaxial, AES and Optics inputs. On the output side, the X26 offers balanced XLR and unbalanced stereo RCA. Note that the analog circuit of the device uses a symmetrical architecture without conversion with a total separation of the two outputs.
Product type | DAC |
DAC Chip | 2x ES9038Pro |
Inputs | 1x USB-B 1x I2S LVDS via HDMI 1x Coaxial S/PDIF 1x AES/EBU 1x Optical Toslink |
Outputs | 1x Single-ended stereo RCA 1x Balanced XLR |
Supported sampling rates | Coaxial, AES : PCM up to 24bit 384kHz / DSD DoP up to DoP128 Optique : PCM up to 24bit 192kHz / DSD DoP up to DoP64 USB, I2S : PCM up to 32bit 768kHz / DSD DoP up to DoP256 / DSD Natif up to DSD512 |
Frequency response | 20Hz - 20kHz +/-0.1dB |
Dynamic range | 125dB |
Crosstalk | -137dB @ 1kHz |
THD+N | < 0.0006% @ 20Hz-20kHz |
Intermodulation distorsion (IMD) | < 0.0006% |
RCA output level | 2.5Vrms (Volume 0dB) |
RCA output impedance | 100Ω |
XLR output level | 5Vrms (Volume 0dB) |
XLR output impedance | 100Ω |
Supply voltage | AC 115/230V 50/60Hz |
Consumption | < 60W |
Dimensions | 330 x 260 x 65mm |
Case material | Brushed Aluminium |
Color | Black |
Input | SPDIF |
Input | I2S via HDMI |
Input | XLR |
Input | Optical |
Output | RCA |
Output | XLR |
DAC / ADC Chip | ES9038PRO |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Black |
Networking | No |
Remote Control | No |
