GUSTARD X26 PRO Balanced DAC 2x ES9038Pro XMOS Bluetooth 5.0 MQA 32Bit 768kHz DSD512 Black
An enhanced version of the Gustard DAC-X26, the X26Pro offers a series of improvements designed to make it both more powerful and more versatile. These now include a Bluetooth 5.0 receiver, improved clocking, MQA file decoding and improved heat dissipation.
By buying this product you get 145 loyalty points
Reference : 15096
1 459,00 €tax incl.
1 215,83 € tax excl.
This is the version with the latest Gustard firmware for X26 PRO.
Gustard X26 Pro
Gustard X26Pro DAC Symétrique 2x ES9038Pro XMOS Bluetooth 5.0 MQA 32Bit 768kHz DSD512 Noir
The X26Pro's no-compromise design incorporates high-end audio components to deliver rich, accurate, dynamic audio as close to the original signal as possible.
ES9038Pro Dual DAC
At the heart of the X26Pro are two DAC ESS ES9038Pro DAC chips for digital-to-analog conversion. Each channel therefore has its own conversion chip and power supply to deliver the best possible audio performance. In addition, these chips support high sample rates, which in the case of the Gustard X26Pro can go up to 32bit 768kHz PCM and DSD512 on the USB and I2S inputs.
These chips are accompanied by a Class A LPF integrating only discrete components, specifically optimized for the ES9038Pro DACs.
Ultra low noise clock synthesizer
The X26Pro incorporates a K2 clock synthesizer, which provides a second clock signal and synchronizes decoding. This allows DAC performance to be independent of the source equipment.
Altera MAX II CPLD
The logic functions of the X26Pro are entrusted to a CPLD, including a clock management system, second PLL digital processing, DoP decoding and many other functions that contribute greatly to the performance of the device.
Filters & SHARC DSP
The Gustard X26Pro offers several digital filters, PCM and DSD, to adapt the sound reproduction to your listening and audio system, while reducing residual noise.
In order to offer high quality filters, Gustard has chosen to develop its own filters using a DSP Analog Device SHARC chip. This solution integrates an anti-aliasing algorithm designed by Gustard, using a high-precision 64bit floating point system. Moreover, this algorithm has been optimized to work perfectly with ESS DACs and ensure the best possible sound quality.
XMOS USB Interface
Behind the USB-B input of the X26Pro is a high-performance XMOS XU216 USB interface. This interface enables fast and efficient data processing, while supporting high-resolution data streams.
Power supply
The power supply for the X26Pro uses two toroidal transformers and a discrete 8-channel hybrid I/V conversion circuit. This provides the entire system with a consistent and extremely clean and stable power supply, which is essential for high-quality sound reproduction.
In addition, each channel of the X26Pro's analog circuitry uses an independent power rail to limit interference and noise.
Bluetooth 5.0
New in this Pro version of the Gustard DAC-X26 is the integration of a Qualcomm CSR8675 Bluetooth 5.0 receiver chip. This chip allows you to broadcast your music remotely and in high quality, thanks to the support of protocols such as aptX HD and LDAC.
Connectivity
The Gustard X26Pro benefits from a complete set of connectors capable of adapting to many audio systems. Inputs include USB-B, I2S LVDS over HDMI, Coaxial, AES, Optical and Bluetooth reception. On the output side, the X26Pro offers balanced XLR and unbalanced stereo RCA. Note that the analog circuitry of the device uses a balanced architecture without conversion with a total separation of the two outputs.
I2S Pinout
Product typeBalanced DAC
Inputs1x USB-B
1x I2S via HDMI LVDS
1x Coaxial
Bluetooth 5.0
1x AES/EBU
1x Optical
1x BNC
Outputs1x Balanced stereo XLR
1x Single-ended stereo RCA
DAC Chips2x ESS ES9038Pro
Bluetooth chipQualcomm CSR8675
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
USB InterfaceXMOS XU216
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA
I2S : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
AES / Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Power supply115-230V AC (switchable supply voltage)
Housing materialAluminum alloy
Dimensions330 x 260 x 65mm
Weight7.5kg
Gustard X26Pro DAC Symétrique 2x ES9038Pro XMOS Bluetooth 5.0 MQA 32Bit 768kHz DSD512 Noir Gustard X26Pro DAC Symétrique 2x ES9038Pro XMOS Bluetooth 5.0 MQA 32Bit 768kHz DSD512 Noir Gustard X26Pro DAC Symétrique 2x ES9038Pro XMOS Bluetooth 5.0 MQA 32Bit 768kHz DSD512 Noir Gustard X26Pro DAC Symétrique 2x ES9038Pro XMOS Bluetooth 5.0 MQA 32Bit 768kHz DSD512 Noir Gustard X26Pro DAC Symétrique 2x ES9038Pro XMOS Bluetooth 5.0 MQA 32Bit 768kHz DSD512 Noir Gustard X26Pro DAC Symétrique 2x ES9038Pro XMOS Bluetooth 5.0 MQA 32Bit 768kHz DSD512 Noir Gustard X26Pro DAC Symétrique 2x ES9038Pro XMOS Bluetooth 5.0 MQA 32Bit 768kHz DSD512 Noir Gustard X26Pro DAC Symétrique 2x ES9038Pro XMOS Bluetooth 5.0 MQA 32Bit 768kHz DSD512 Noir
InputBNC
InputI2S via HDMI
InputAES/EBU
OutputJack 3.5mm
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipES9038PRO
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
8 reviews
Gustard 26x pro
Merci beaucoup pour cet appareil. Pas encore rôdé mais déjà un beau son, une belle ouverture. Musique détourée. Vraiment superbe.
Merci beaucoup pour l'expédition avec surremballage et rapidité.
Cordialement.
This review has been posted for GUSTARD X26 PRO Balanced DAC 2x ES9038Pro XMOS Bluetooth 5.0 MQA 32Bit 768kHz DSD512 Black
très bon dac
dac ayant toutes les qualités qu'on peut en attendre.
les (-) j'ai déjà eu de plus beaux timbres mais le produit est neuf...
les (+) excellente dynamique et suivi mélodique. Maillon sensible car
c'est le premier dac qui offre autant de différences d'écoute à chaque changement de câble numérique. Meilleur résultat obtenu avec le câble AES/EBU de Canare. J'ai obtenu un resultat encore meilleur en le découplant avec 3 VIABLUE TRI SILVER et un mode NOS plutôt que OS préconiser par Gustard
Dac o dac
Bonjour,
Hola Benjamin,
Après lecture de ton post, j’ai décidé de franchir le pas et de faire une entorse à la famille Naim. Le Gustard a remplacé le Ndac qui ne déméritait pas. Le x26 ajoute plus de définition et dynamisme sans tomber dans la fatigue auditive. Il possède aussi plus de fonctionnalités. Donc je suis entièrement satisfait de cet investissement somme toute raisonnable au vu de la qualité de fabrication. Il peut être amélioré en utilisant un cordon secteur qualitatif (chez Audiophonics, il y en a à prix raisonnable), mais aussi en remplaçant le fusible d’origine par un Gustard fuse hifi (achat en ligne abroad) qui le rend encore plus désirable. Si ma modeste contribution peut vous aider à franchir le pas…
Musicalement,
JFT
Un DAC de référence...
Achat réalisé après avoir lu pas mal de chose à son sujet, ce DAC vient en renfort à un OPPO UDP-203 que je pensais bon via ses sorties analogiques. Quelle surprise de constater qu’il n’en était rien. Le Dac Gustard x26pro fait faire un bon énorme en qualité de restitution à mon équipement. La scène sonore est ample avec beaucoup de détails, mais sans jamais être fatiguant à l’écoute. (J’ai donc commandé la carte I2S pour l’OPPO ainsi que ses horloges FEMTO ;-) Vu la qualité du DAC, il est impératif de lui fournir des entrées très qualitatives, il le vaut bien.
J’utilise aussi le X26pro avec mon Raspberry pour Spotify via le port USB (alimentation linéaire, OCXO sur toutes les horloges). Je n’avais jamais entendu une telle qualité via Spotify. Bref, le X26pro est si addictif que je passe beaucoup de temps à écouter et ré-écouter mes enregistrements préférés.
A noter, les basses sont profondes, impressionnantes. Je dirai même qu’elles sortent de catacombes maintenant. Je ne savais pas que mes enceintes étaient capables d’aller aussi bas, et mon caisson encore moins. Toutefois, pas d’effet de basse qui trainent, c’est percutant quand il le faut, rapide, sec parfois, un vrai régal…
Mon équipement, préampli double mono et deux blocs mono, tous en classe A et cablés en symétrique, DAC compris. Mon X26pro est piloté par une horloge OCXO asservis par GPS alimenté 24H/24, ce qui permet de démarrer à froid le X26pro sans se soucier de réchauffer l’électronique.
Mon avis, le DAC X26 Pro est la révélation de l’année…
DAC Au Top
Ce DAC est tout simplement excellent !
la connectique est complete, je l'utlise connecté en I2S a un streamer PI2AES, le brochage est compatible par défaut !
le son est excellent, et les trois filtres font une réelle difference.
l'enorme plus : Le MODE NOS, qui débraie les filtres internes, et qui me permet d'envoyer un flux upsamplé en amont par Hqplayer.
Le réalisme et le naturel de la restitution ont encore fait un bon en avant !
Il me reste explorer la possibilité d'ajouter une horloge externe...
Ce DAC est une vraie réussite, et couplé a hqplayer, il est encore meilleur...
 (3)
An enhanced version of the Gustard DAC-X26, the X26Pro offers a series of improvements designed to make it both more powerful and more versatile....
