ROSE HIFI RD160 Balanced DAC Black
Rose HiFi's RD160 is an aesthetically pleasing balanced DAC, based on a duo of AK4191 and AK4499EX chips per channel, capable of upsampling signals up to PCM 32bit 768kHz and DSD512. The brand's expertise ensures a design quality that leaves no detail to chance, having identified every source of noise and potential distortion to provide a suitable solution.
By buying this product you get 529 loyalty points
Reference : 19882
5 299,00 €tax incl.
4 415,83 € tax excl.
Rose HiFi RD160 Balanced DAC AK4499EXEQ + AK4191EQ PCM 32bit 768kHz DSD512 Black
Rose HiFi RD160 : 3/4 view
Rose HiFi RD160: Refined aesthetics
The RD160's appearance perfectly blends cutting-edge technology with the most refined aesthetics. Its aluminum case is machined from a single block, and benefits from a design that reduces the number of joints to an absolute minimum, so as to minimize potential vibrations. Heat sinks have been placed on both sides, ensuring that the RD160 maintains a regulated temperature, even during prolonged use. Last but not least, the hidden display, harmoniously integrated into the front panel, offers a rendering of rare elegance.
Rose HiFi RD160: DPC module (Digital Processing Core)
The RD160's digital stage incorporates the Rose DPC™ module, designed to ensure that all processing blocks maintain the highest level of signal accuracy to deliver faithful, detailed sound reproduction. This module precisely synchronizes input digital signals in various ways to a high-precision OCXO clock, and aligns them to I2S signals. This process applies clock synchronization and locking to minimize jitter, particularly when processing high-resolution audio signals, for precise signal processing and therefore natural, transparent sound. The user interface and GUI configuration circuits, as well as the digital audio signal circuitry, are completely separated to effectively block distortion and interference. This design enables the RD160 to deliver high-fidelity sound with a high-quality digital signal and compatibility with a wide range of digital formats.
Rose HiFi RD160 : DPC module diagram
Rose HiFi RD160: ROSE CIM architecture
The Rose CIM™ architecture aims to maximize sound quality through complete isolation of the digital and analog parts. The RD160's DAC module is a two-chip solution, with the AK4191 chip handling the digital filtering and initial delta-sigma modulation steps, while the AK4499EX chip performs the digital-to-analog conversion. By completely separating digital and analog circuits with this architecture, the RD160 completely blocks the noise generated during processing of the respective signals, resulting in an extremely high signal-to-noise ratio (SNR) and first-rate analog output signal quality.
Rose HiFi RD160 : Operating diagram
What's more, by individually assigning a DAC module to each channel and designing the analog output circuit to be fully symmetrical, any noise that might be generated between channels is completely blocked. This architecture enables the RD160 to achieve an exceptional dynamic range, reproducing with clarity and precision the finest details of the original sound with a clear stereo image.
Rose HiFi RD160: 3 separate linear power supplies
Developed specifically by HiFi ROSE, the RD160's linear power supply is designed to deliver the best sound quality. Based on an ultra-low-noise chipset, the power supply is designed to independently power digital input ports and analog output ports. This power supply effectively suppresses the noise that can occur in each circuit, such as digital processing, clock and analog output, minimizing mutual interference and crosstalk between the various stages. By providing a stable power supply tailored to the needs of each stage, it maintains signal integrity and increases the dynamic range and resolution of the DAC. It also reduces jitter and optimizes spatialization, delivering a wider, more accurate soundstage and clearer images.
Rose HiFi RD160 : Power supply circuit
Rose HiFi RD160: J-FET Op-Amp
The RD160 is equipped with a high-quality dual J-FET operational amplifier, boasting excellent speed of response, wide dynamic range and low harmonic distortion, while having the good taste to use an OFC copper leadframe to ensure perfect conductivity. The choice of the RD160's op-amp has been the subject of a rigorous and meticulous process to obtain a natural and lively sound, ensuring you get the best possible performance.
Rose HiFi RD160 : J-FET Op-Amp
Rose HiFi RD160: ROSE NRA filter
The analog stage with ROSE NRA filter ensures a perfectly flat frequency response, even in the lowest frequency bands. As a result, the RD160 has a wide, stable frequency response, with no roll-off across the entire bandwidth, and clearly and faithfully transmits the original information contained in high-resolution audio, from the deep, heavy infrabass to the ultra-high frequencies.
Rose HiFi RD160 : Réponse en fréquence
Rose HiFi RD160: OCC / OFC copper wiring
To ensure impeccable sound quality, the wiring for the digital input signal, the external clock signal and the power supply is made of OFC copper, while the wiring for the analog outputs is made of monocrystalline OCC copper, guaranteeing optimum conductivity at every stage of signal processing.
Rose HiFi RD160 : OFC and OCC circuit
Rose HiFi RD160: OCXO internal clock
The high-precision OCXO clock fitted to the RD160 increases the accuracy of digital inputs and provides a highly accurate clock signal. The OCXO is the most accurate and stable clock currently available, and is unaffected by temperature variations. Conventional crystals tend to vibrate differently according to temperature, which can cause jitter in the audio signal. In contrast, OCXO clocks suppress this jitter by maintaining a constant temperature at all times, producing a perfectly stable clock signal.
Rose HiFi RD160 : OCXO clock
Rose HiFi RD160: Adjustable output level
The maximum permissible input voltage for amplifiers varies according to manufacturer and model. If the output voltage of the source device exceeds this limit, clipping may occur, resulting in sound distortion. The RD160 offers a wide range of output level options, from 1V to 9V, guaranteeing clean, clipping-free sound and perfect compatibility with all amplifiers. By activating this function, you can adjust the level via the rotary knob, enabling you to connect the RD160 directly to a power amplifier without the need for a separate preamplifier.
Rose HiFi RD160: Upsampling and digital filter
The RD160 offers the possibility of increasing the sampling rate of your signal via several options (bypass, upscale to PCM, and upscale to DSD) and supports signals up to 32bit 768 kHz PCM and DSD512. In addition, six digital filters with different responses are available, allowing you to choose according to your listening preferences. Both functions can be easily adjusted using the buttons on the left-hand side of the front panel, and are displayed on the live screen.
Rose HiFi RD160: USB Optical & External clock inputs
The USB SFP with optical conversion function completely blocks the digital noise generated by the source device. The Rose RS130 (sold separately), ideally suited for use with the RD160, also supports the USB SFP connection and can transmit data to the RD160 perfectly cleanly and noise-free.
The RD160 also features inputs for 75Ω and 50Ω external clocks. By using the master clock, jitter caused by optical, coaxial, AES/EBU and USB connections from the source to the DAC is eliminated, while ensuring perfect synchronization of the devices.
Rose HiFi RD160 : USB optique SFP et entrées horloges externes
Rose HiFi RD160 : Connectivity
Rose HiFi RD160 : Schéma des connectique
1Circuit breaker reset
2Earth plug
3Right channel XLR output
4Right channel RCA output
5Trigger input and output
6AES/EBU input
7Coaxial inputs
8Clock signal inputs
9Left channel RCA output
10Left channel XLR output
11Power input
12SVC port (firmware update)
13Optical Toslink input
14HDMI I2S input
15USB-B input
16USB SFP input (Optical USB)
Product typeVolume DAC
DAC chips2x AK4499EXEQ
2x AK4191EQ
Power supply3x Independant toroidal transformer
CPURK3128 Quad Core Cortex-A7MP
RAM mamory1GB 1866Mhz DDR3
Flash memory8GB eMMc
Internal clockOCXO clock
Inputs1x USB SFP
1x USB-B 2.0
1x HDMI I2S
1x Coaxial RCA
1x Coaxial BNC
1x Optical Toslink
1x AES/EBU
Outputs1x Steroe XLR
1x Stereo RCA
Supported sampling ratesUSB SFR / USB-B / HDMI I2S : PCM 32bit 768kHz / DSD512
Coaxial RCA / Coaxial BNC / AES/EBU : PCM 32bit 384kHz / DSD128
Optical Toslink : PCM 32bit 192kHz / DSD64
External clock inputs1x BNC 75Ω (10MHz)
1x SMA 50Ω (10MHz)
Output levels1V ~ 9V
Digital filtersSharp
Sharp Slow
Short Sharp (default)
Short Slow
Super Slow
Low Short
Input sensitivity0dBF 1kHz
Output impedance300Ω
Output voltageRCA : 4.5Vrms
XLR : 9Vrms
THD0.005%
SNR124dB
Residual noiseRCA : 0.3mV
XLR : 0.4mV
Crosstalk-124dB
Frequency response10Hz - 20kHz (-0.3dB)
10Hz - 50kHz (-1.5dB)
10Hz - 73kHz (-3.0dB)
Operating temperature0 ~ 40°C
Storage temperature-10 ~ 50°C
Supply voltage110-120V AC / 220-240V AC 50/60Hz
ConsumptionStandby : 0.3W
Working : 30W
Weight10kg
Package1x Rose HiFi RD160
1x Remote control
2x SFP cables
1x Optical fiber cable
1x Power cable
InputBNC
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipAK4191
DAC / ADC ChipAK4499EX
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
ROSE HIFI RD160 Balanced DAC AK4499EXEQ + AK4191EQ PCM 32bit 768kHz DSD512 Black
Rose HiFi's RD160 is an aesthetically pleasing balanced DAC, based on a duo of AK4191 and AK4499EX chips per channel, capable of upsampling...
