By buying this product you get 109 loyalty points
The J.C Acoustics UDP-6PRO is a DAC and headphones amplifier based on audiophile components. It features an ES9039SPRO DAC chip and an XU216 XMOS USB interface for support of high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. It also boasts a balanced Class AB headphone amplifier circuit with four TPA6120A2 chips for output power of up to 7500mW under 32 ohm on its balanced headphone output.
The device is completed by a high-performance power supply consisting of a 60VA transformer and no less than 6 filter capacitors. Each component is independently powered for low noise. The front panel features an attractive 3” color IPS display with a practical, modern interface. As for connectivity, the UDP-6PRO has plenty to offer, with numerous digital inputs, two headphone outputs (6.35mm jack/4.4mm jack) and two analog outputs (RCA/XLR).
The UDP-6PRO benefits exclusively from high-quality components and an audiophile architecture to get the best out of your audio sources.
The UDP-6PRO's digital-to-analog conversion is based on an ESS ES9039SPRO DAC chip and an XMOS XU216 USB interface. This enables it to support high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. In addition, an SC8422 chip supports optical/coaxial SPDIF signal processing up to 24bit 192kHz.
The headphones amplifier stage features a balanced architecture with 4 OPA1642 and 4 TPA6120A2 amplifier chips for detailed, powerful sound reproduction. This configuration offers excellent dynamics and resolution across all frequencies. As a result, the UDP-6PRO's headphone outputs deliver substantial power, making it a headphone amplifier capable of driving high-end, high-impedance headphones.
Balanced 4.4mm jack headphones output power
6.35mm jack headphones output power
The front panel of the UDP-6PRO headphones amplifier DAC features a beautiful 3” color IPS display. This is accompanied by a modern, practical interface. In fact, it provides access to the various information concerning the current playback, as well as navigation between the device's different parameters.
The UDP-6PRO's power supply circuit is based on an optimised 60VA custom-made OFC copper transformer, six filter capacitors totalling almost 30,000µF and a regulated five-line power supply, allowing a stable and clean current to be delivered independently to each component of the unit. This enables the UDP-6PRO to achieve exceptional audio performance.
| 1 | Color IPS display |
| 2 | Balanced 4.4mm headphones output |
| 3 | Single-ended 6.35mm headphones output |
| 4 | Multifunction button |
| 5 | Balanced XLR output |
| 6 | Single-ended RCA output |
| 7 | Coaxial input |
| 8 | Toslink optical input |
| 9 | I2S LVDS input via HDMI |
| 10 | USB-B input |
| 11 | Power supply |
| Specifications | |
| Product type | DAC / Headphones amplifier |
| DAC chip | ES9039SPRO |
| Amplification chips | 4x TPA6120A2 |
| OPA | OPA1642 |
| Inputs | 1x USB-B 1x Coaxial 1x Optical Toslink 1x I2S LVDS via HDMI |
| Outputs | 1x Single-ended RCA output 1x Balanced XLR output 1x Balanced 4.4mm jack headphones output 1x Single-ended 6.35mm jack headphones output |
| Supported sample rates | USB: PCM 32bit 768kHz, DSD512 (DoP & Native) Coaxial / Optical toslink: 24bit 192kHz I2S LVDS via HDMI: PCM 32bit 768kHz, DSD512 (DoP & Native) |
| DAC specifications (balanced XLR output) | |
| Frequency response | 20Hz-40kHz (+/-0.2dB) |
| THD+N | 0.00015% (-6dB @ 1kHz, A-WT) |
| SNR | 120dB |
| Channel separation | -133dB @ 1kHz |
| Line output power | RCA: 2.3Vrms XLR: 4.6Vrms |
| Headphones amplifier specifications (balanced 4.4mm jack output) | |
| THD+N | 0.00025% (4Vrms @ 1kHz, A-WT) |
| Frequency response | 133dB |
| Channel separation | -133dB |
| Output power | 4.4mm balanced jack: 7500mW @ 32 ohm / 900mW @ 300 ohm / 450mW @ 600 ohm 6.35mm unbalanced jack: 1850mW @ 32 ohm / 225mW @ 300 ohm / 112mW @ 600 ohm |
| General | |
| Power supply | 230V AC (Fusible 1.6A) |
| Power consumption | < 25W Standby: 3W |
| Color | Silver |
| Dimensions | 239 x 50 x 208mm |
| Weight | 3kg |
| Package | 1x J.C Acoustics UDP-6PRO 1x USB-A to USB-B cable 1x Power cable |
| Input | USB |
| Input | Optical |
| Input | SPDIF |
| Input | I2S via HDMI |
| Output | XLR |
| Output | Jack 4.4mm |
| Output | RCA |
| Output | Jack 6.35mm |
| DAC / ADC Chip | ES9039MPro / ES9039MSPro |
| Color | Silver |
| Class | Class A / AB |
| Networking | No |
| Remote Control | No |
