By buying this product you get 53 loyalty points
As performant as it is versatile, the Loxjie D40 Pro DAC is the ideal ally to help you enjoy your music in the best possible conditions. With its high-end digital-to-analog conversion chip supporting high-resolution files, its perfectly mastered circuits and its numerous functions, the Loxjie D40 Pro offers rich and precise sound quality, and will fit into the vast majority of systems.
At its heart, the D40 Pro conceals an ES9039MSPro digital-to-analog conversion chip. Flagship of ESS, this 32-bit DAC offers excellent performance, with THD+N as low as -125dB, for extremely precise and pure sound reproduction. The chip also supports high-resolution audio files, so you can get the most out of your music.
When the input signal is stable, the D40 Pro reduces the DPLL value to improve the unit's clocking performance. On the contrary, when the input signal lacks stability, increasing the value of this function will restore uninterrupted signal and sound.
The D40 Pro also features 7 PCM filters and 4 DSD filters. These allow you to adjust the device's sound reproduction to suit your listening style or audio system.
In addition to its DAC section, the Loxjie D40 Pro provides a powerful headphone amplifier with an output impedance close to 0Ω and two selectable gain levels, thus adapting to the vast majority of headphones on the market. The device's independent volume control lets you freely adjust the sound level of the headphone and line outputs.
Thanks to its high-end DAC and high-quality interfaces, the D40 Pro supports high-resolution files up to PCM 32bit 768kHz and DSD512. The result is a rich, detailed sound experience, allowing you to enjoy every detail of your music.
As well as supporting high sampling rates, the Loxjie D40 Pro also features an MQA (Master Quality Authenticated) decoder. This particular format ensures high sound quality by providing files authenticated by the artist, the record company or the song's rights holders. The D40 Pro is also compatible with the MQA-CD format.
With Qualcomm's Bluetooth 5.0 receiver, you can wirelessly stream and control your music directly from a smartphone or tablet, for example.
The D40 Pro's I2S over HDMI input offers two modes, using different pinouts. Here too, the D40 Pro demonstrates its versatility, adapting to your device and source signal.
Supplied with an IR remote control, the D40 Pro can be controlled remotely. This gives access to all the device's functions and settings.
The D40 Pro's circuitry favors the use of high-quality electronic components to deliver the best possible performance. These include a XMOS XU-316 USB interface supporting high-resolution streams, OPA1612 OPAs with very low distortion and noise, and a power supply stage using several low-noise voltage regulators and discrete components.
1 | ON/OFF switch |
2 | Filter selection |
3 | Input selection |
4 | Output selection |
5 | Screen |
6 | Multifunction knob |
7 | Single-ended Jack 6.35mm headphone output |
8 | Balanced Jack 4.4mm headphone output |
9 | Balanced XLR 4 pins headphone output |
10 | Single-ended stereo RCA output |
11 | Balanced stereo XLR output |
12 | AES/EBU input |
13 | Bluetooth antenna |
14 | I2S input |
15 | Optical Toslink input |
16 | Coaxial input |
17 | USB input |
18 | 100-240VAC power input |
"Loxjie has managed to reverse the trend of rising prices for this type of device on the market with the D40 Pro. This high-performance DAC headphone amplifier comes at a reasonable price, and boasts excellent headphone amplification performance thanks to its balanced connectivity compared to the majority of devices in its category."
Product type | DAC |
DAC chip | ESS ES9039MSPro |
Inputs | Bluetooth 1* USB-B 1* Optical Toslink 1* Coaxial 1* I2S via HDMI 1* AES/EBU |
Outputs | 1* Single-ended stereo RCA 1* Balanced stereo XLR 1* Single-ended Jack 6.35mm headphone output 1* Balanced Jack 4.4mm headphone output 1* Balanced XLR 4 pins headphone output |
USB interface | XMOS XU-316 |
USB transmission | Asynchronous |
USB compatibility | Windows 7/8/8.1/10/11 Mac OS X Linux |
THD+N | 0.00005% (-125dB) |
Dynamic range | 133dB |
SNR | RCA: 128dB XLR: 133dB |
Bluetooth version | 5.0 |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD, LDAC |
Supported sampling rates | USB, I2S: PCM up to 32bit 768kHz, Native DSD up to DSD64 Optical, Coaxial, AES/EBU: PCM up to 24bit 192kHz, DoP64 |
Output impedance | 100Ω |
Output level | XLR: 5.2Vrms RCA: 2.5Vrms |
Headphone output power | 2x 6000mW @ 16Ω 2x 3000mW @ 32Ω 2x 700mW @ 300Ω 2x 350mW @ 600Ω |
Supply voltage | 100-240VAC (power cable included) |
Consumption | 5W |
Dimensions (W*D*H) | 240*195*43mm |
Weight | 1.1kg |
Color | Gray |
Package | 1* Loxjie D40 Pro 1* Power cable 1* USB cable 1* Bluetooth antenna 1* Remote control |
Input | Optical |
Input | I2S via HDMI |
Input | SPDIF |
Input | Bluetooth |
Input | AES/EBU |
Input | USB |
Output | RCA |
Output | Jack 6.35mm |
Output | XLR |
Output | Jack 4.4mm |
DAC / ADC Chip | ES9039MPro / ES9039MSPro |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Color | Gray |
Networking | No |
Remote Control | Yes |
