LOXJIE D60 DAC Headphone Amplifier Silver
With its D60 DAC / headphone amplifier, Loxjie offers a modern, high-performance device, carefully designed and equipped with audiophile components. It incorporates an ES9039MSPRO DAC chip with MQA decoder, as well as an XMOS XU-316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz, DSD512 and MQA-CD. Versatile, it features numerous digital inputs, including an HDMI I2S input and Bluetooth 5.1 reception thanks to a latest-generation Qualcomm chip.
By buying this product you get 53 loyalty points
Reference : 19884
539,00 €tax incl.
449,17 € tax excl.
Shipping date: 03-04-2026.
Loxjie D60 DAC Headphone amplifier ES9039MSPRO Bluetooth 5.1 32bit 768kHz DSD512 MQA-CD Silver
LOXJIE D60 picture
With its D60 DAC / headphone amplifierLoxjie offers a modern, high-performance device, carefully designed and equipped with audiophile components. It incorporates an ES9039MSPRO DAC chip with MQA decoder, as well as an XMOS XU-316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz, DSD512 and MQA-CD. Versatile, it features numerous digital inputs, including an HDMI I2S input and Bluetooth 5.1 reception thanks to a latest-generation Qualcomm chip.
On the headphone amplification side, it benefits from a balanced architecture and offers three outputs: single-ended 6.35mm jack, balanced 4.4mm jack and balanced XLR 4 pins. It is capable of delivering power up to 2x350mW at 600Ω and 2x6000mW at 16Ω, enabling it to drive all types of headphones. The package is rounded off by a nice display and user-friendly interface, as well as the possibility of using numerous PCM and DSD filters. As for its RCA and XLR line outputs, they feature adjustable output levels of 2.5Vrms and 5.2Vrms maximum respectively.
Loxjie D60: ES9039MSPRO DAC and XMOS XU-316 USB interface
Loxjie has equipped its D60 with an ES9039MSPRO DAC chip and XMOS XU-316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz, native DSD up to DSD512 and MQA-CD. As a result, the D60 lets you enjoy audio files of the highest possible resolution for rich, precise sound reproduction.
Photo of ES9039MSPRO DAC chip
Loxjie D60: A balanced headphone amplifier circuit
The symmetrical architecture of the D60's headphone amplifier circuit limits noise and interference levels, while greatly enhancing the dynamic range of the unbalanced 6.35mm jack, balanced 4.4mm jack and balanced 4-pin XLR headphone outputs. Headphone listening with the D60 is rich in detail. What's more, it boasts a power reserve capable of driving headphones with impedances ranging from 16 ohm to 600 ohm:
  • 2x6000mW @ 16Ω
  • 2x3000mW @ 32Ω
  • 2x700mW @ 300Ω
  • 2x350mW @ 600Ω
Photo of LOXJIE D60 headphone outputs
LOXJIE D60 Bluetooth functionality
Loxjie D60: Bluetooth 5.1
A latest-generation Qualcomm Bluetooth 5.1 receiver chip enables the D60 to support standard SBC and AAC codecs, as well as high-resolution aptX and aptX HD codecs. This provides reliable, stable wireless transmission quality for fast, convenient use with a smartphone, for example.
Loxjie D60: 7 PCM and 4 DSD filters
The Loxjie D60's various filters can be used to modify the signal's transient response to adapt to different types of source and optimize sound reproduction.
LOXJIE D60 PCM and DSD filters
Loxjie D60: HDMI I2S input
The D60's HDMI I2S input enables it to retrieve signals from a variety of sources, thanks to two available interface modes: normal or inverted.
Photo of LOXJIE D60 HDMI I2S pin outs
Loxjie D60: audiophile components
OPA1612 picture
11x OPA1612
The use of these eleven OPAs enables fast, instantaneous multichannel processing with reduced latency.
Photo of OPA6120A
3x OPA6120A
The balanced headphone amplifier circuit features three high-quality output interfaces.
Zoom on the clock circuit
Optimized clock circuit
The clock circuit is optimized for low jitter.
Focus on power supply components
Discrete power supply components
Discrete linear regulators and low-noise components for clean power supplies to analog circuits.
Loxjie D60: Display with intuitive interface and Bluetooth remote control
On the front of the D60 is a beautiful screen with an intuitive, modern and dynamic user interface. It also features a Bluetootth remote control for convenient remote control.
LOXJIE D60 interface and remote control photo
Loxjie D60 overview
Loxjie D60 overview
1Screen
2Multifunction button
3Single-ended 6.35mm jack headphone output
4Balanced 4.4mm jack headphone output
5Balanced XLR 4-pin headphone output
6Single-ended RCA line output
7Balanced XLR line output
8AES/EBU input
9Bluetooth antenna
10HDMI I2S input
11Toslink optical input
12Coaxial input
13USB-B input
14Power input / Power switch
Product typeDAC / Headphone amplifier
DAC chipES9039MSPRO
USB interfaceXMOS XU-316
Inputs1x USB-B
1x Coaxial
1x Optical Toslink
1x HDMI I2S
1x AES/EBU
Bluetooth
Outputs1x Single-ended RCA line output
1x Balanced XLR line output
1x Single-ended 6.35mm jack headphone output
1x Balanced 4.4mm jack headphone output
1x XLR 4-pin balanced headphone output
Supported sample ratesUSB: PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA-CD
Coaxial, Optical, AES/EBU: PCM up to 24bit 192kHz, DSD DoP64
THD+N0.00005% (-125dB)
Dynamic rangeRCA: 127dB
XLR: 132dB
SNRRCA: 127dB
XLR: 132dB
Line output impedance100Ω
Line output levelRCA: 2.5Vrms
XLR: 5.2Vrms
USB transmissionAsynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11
MAC OS
Linux
Unbalanced headphone output power2x3000mw @ 16Ω
2x1500mw @ 32Ω
2x350mW @ 300Ω
2x175mW @ 600Ω
Balanced headphone output power2x6000mw @ 16Ω
2x3000mw @ 32Ω
2x700mW @ 300Ω
2x350mW @ 600Ω
Power supply100-240V AC
Energy consumption< 40W
Standby: < 0.5W
ColorSilver
Dimensions245 x 196 x 46mm
Weight1.495kg
Package1x DAC / Headphone amplifier Loxjie D60
1x Remote control
1x Bluetooth antenna
1x USB-B to USB-A cable
1x Mains cable
Loxjie D60 measurements
InputAES/EBU
InputI2S via HDMI
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ColorSilver
ClassN/A
Remote ControlYes
LOXJIE D60 DAC Headphone amplifier ES9039MSPRO Bluetooth 5.1 32bit 768kHz DSD512 MQA-CD Silver
With its D60 DAC / headphone amplifier, Loxjie offers a modern, high-performance device, carefully designed and equipped with audiophile...
