SMSL D1SE Balanced ES9038PRO DAC CPLD Altera XMOS 32bit 768kHz DSD512 Black
The D1se from SMSL is an extremely powerful DAC, based on a symmetrical architecture using a high-end ESS ES9038Pro digital to analog conversion chip. Taking advantage of a flawless design, it will satisfy the most demanding audiophiles.
4.7 / 5
By buying this product you get 84 loyalty points
Reference : 15355
849,00 €tax incl.
707,50 € tax excl.
SMSL D1se
SMSL D1se DAC ES9038Pro Symétrique CPLD Altera XMOS 32bit 768kHz DSD512 Noir
MQA Support
The SMSL D1se is able to decode MQA (Master Quality Authenticated) audio files. These are the guarantee of a restitution quality as close as possible to the original studio recording for an incomparable listening.
ES9038Pro DAC & High-end components
The D1se uses an ESS ES9038Pro DAC chip for its conversion stage. This one offers incredible sound performances and excellent measurements, with notably a SNR of 140dB and a THD+N of -122dB. In addition, this 32bit 8-channel chip ensures a very low distortion of 0.00009% (-121dB) and supports high-resolution audio streams up to PCM 32bit 768kHz and DSD512.
All the circuits of the D1se also benefit from high-end components. We find an ES9311 chip in the power supply stage, allowing to provide the DAC with a low noise electrical signal. This power supply stage also embeds Nichicon KG filtering capacitors as well as a high quality Noratel toroidal transformer. An XMOS XU-216 32bit USB interface is also used to process USB streams quickly and efficiently.
Bluetooth Transmission
The SMSL D1se embeds a Bluetooth 5.0 receiver and an antenna, allowing you to remotely broadcast your music, directly from your smartphone. Moreover, it supports the aptX codec, ensuring a fast and stable transmission for a quality of restitution close to that of the CD.
1Screen
2IR Receiver
3Input selection button
4Bluetooth button
5Standby LED
6Function button
7Single-ended line output
8Bluetooth antenna
9Optical input
10Balanced line output
11I2S input
12Coaxial input
13USB input
14Power connector (100-240VAC)
Product typeDAC
DAC ChipESS ES9038Pro
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
1x I2S via HDMI
Bluetooth
Outputs1x Single-ended RCA
1x Balanced XLR
THD+N0.00009% (-121dB)
Dynamic rangeXLR : 130dB
RCA : 123dB
SNR130dB
Output impedanceXLR : 207Ω
RCA : 142Ω
USB TransmissionAsynchronous
USB CompatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD64 (DoP)
Bluetooth version5.0
Bluetooth codecsAAC, SBC, aptX
Consumption5W
Standby consumption<0.5W
Housing materialAluminum
Dimensions210 x 39 x 185mm
Weight1.64kg
Package1x D1SE Black
1x Bluetooth antenna
1x Remote
1x Schuko power cable
InputI2S via HDMI
DAC / ADC ChipES9038PRO
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
3 reviews
Petit DAC musical et détaillé
Première Déclinaison du D1, promotion Audiophonics, prux intéressant, délivrant un son très ouvert, belle imagerie, bien, pour quelqu'un qui recherche un appareil musical avec un DAC de pointe ESS non gravé avec un encombrement minimal. Il existe un S2 avec davantage d'OP qui a remplacé celui-ci et le nouveau DAC ESS 9039. Ces modèles ESS ont une belle neutralité, mais ce n'est pas stérile, une alternative intéressante à AKM ou à des R2R d'entrée de gamme.
This review has been posted for SMSL D1SE Balanced ES9038PRO DAC CPLD Altera XMOS 32bit 768kHz DSD512 Black
DAC transparent et silencieux
En remplacement d'un ATOLL 100SE vieillissant, ce DAC est transparent et retranscrit les phonogrammes de façon très exacte et stable. Aucune signature sonore décelable. Ne pardonne rien aux enregistrements de mauvaise qualité.
Utilisé en liaisons RCA avec un amplificateur intégré.
Aucun bruit résiduel transmis à l'amplificateur lorsqu'il n'y a pas de source envoyant un signal. Aucun bruit non plus à la mise sous tension et à l'extinction.
Ne chauffe pratiquement pas.
seul bémol : entrée I2S non compatible avec source munie d'une sortie HDMI ARC (audio), quelles que soient les configurations de l'entrée I2S choisies. D'où le retrait d'un point.
à signaler: DAC détecté par mon PC et utilisable en liaison USB avant même d'avoir téléchargé le pilote dédié. Ce dernier installé, je n'ai vu rien de modifié dans l'utilisation du DAC.
Que la lecture des fichiers se fasse au format natif (flac 16 bits/44 Khz la plupart du temps) ou rééchantillonné en 32 bits/384 Khz ne change pratiquement rien au rendu sonore.
Fonctions MQA et Bluetooth inutiles pour mon usage et donc non testées.
Laurent G.
SMSL D1SE
Big surprise for little money.
I bought this DAC for my weaker setup that I run in my studio.
Minimac M1- HQPlayer- SMSLD1SE- Accuphase E210 - Wharfedale Linton Heritage.
The performance is excellent, the sound is more reminiscent of something between an AKM and R2R than a Sabre.
Surprisingly, it held its own even in my large home setup, but there it competed with the much more expensive Accuphase DP750 and yes - it lost.
But the difference was not abysmal.
It is a suitable DAC for a set (amplifier, cables, loudspeaker) with a total value of around 5,000 EUR.
The D1se from SMSL is an extremely powerful DAC, based on a symmetrical architecture using a high-end ESS ES9038Pro digital to analog conversion...
