SMSL D400ES DAC ES9039MSPro XMOS XU316 11x OPA1612 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA
With its D400ES DAC, SMSL is back on the scene by adopting the latest high-end DAC chip ES9039MSPro from ESS. Associated with very high quality audio circuits and components, the D400ES offers first class performances.
By buying this product you get 79 loyalty points
Reference : 16966
799,00 €tax incl.
665,83 € tax excl.
Shipping date: 20-05-2025.
SMSL D400ES
A DAC that is also versatile, providing a complete connectivity and Bluetooth 5.0 reception, covering the vast majority of uses.
Comparison of the D400ES and D400EX
D400ES
D400EX
Architecture
SDAA
SDAA
MQA Decoder
Yes (via USB, Optical, Coaxial)
DAC Chip
1* ES9039MSPro
1* AK4191 + 2* AK4499EX
OPA
11* OPA1612A
5* OPA1612A + 4* LME49720
THD+N
-124dB @ 4Vrms
-125dB @ 5.2Vrms
-123dB @ 4Vrms
-123.5dB @ 4.7Vrms
Max output level
4.7Vrms
5.2Vrms
ES9039MSPro Next Generation DAC
The SMSL D400ES is equipped with the latest generation of ESS digital/analog converter with the 32bit 8 channel ES9039MSPro chip, a new reference in the world of high-end DACs. It uses ESS' patented Hyperstream® IV technology. Thanks to the QUAD modulator architecture, it offers unprecedented sound quality and audio specifications, including excellent dynamic range and THD+N. It also now incorporates an MQA decoder.
XMOS XU316 USB Interface
The USB input of the D400ES embeds a XMOS XU316 USB interface. This particularly powerful microcontroller allows a fast and efficient processing of audio streams via USB. It also guarantees the support of PCM signals up to 32bit 768kHz and DSD up to DSD512.
MQA & MQA-CD Decoder
With its ES9039MSPro chip, the D400ES becomes capable of decoding and playing the MQA (Master Quality Authenticated) format. This type of file offers a high sound quality, as close as possible to the original studio recording. Each track is also authenticated by the artist, producer or copyright holder. This type of format is notably used on the Tidal streaming platform. In addition, MQA-CD is also supported, allowing this type of file to be played from a CD player.
Bluetooth 5.0 Reception
In addition to its already complete connectivity, the D400ES integrates a Bluetooth 5.0 receiver from Qualcomm. This one offers the possibility of broadcasting and controlling simply its music in wireless, from a smartphone or a tablet for example. The receiver chip used supports the high-resolution transmission codecs aptX HD and LDAC for a quality sound reproduction in Bluetooth.
High quality components
The whole D400ES benefits from a quality design, using only components specially selected for their performance. It features an eight-channel parallel circuit with no less than 11 OPA1612 operational amplifiers, the brand's CK-03 clock system for greatly reduced jitter, and a low-noise regulated power supply stage.
1Screen
2Multi-function button
3FN button
4Menu button
5ON/OFF button
6Single-ended RCA output
7Power input and button
8I2S input
9USB-B input
10Optical Toslink input
11Coaxial input
12AES/EBU input
13Balanced XLR output
14Bluetooth antenna connector
SMSL D400ES test by Audio Science Review (Amir)
"SMSL D400ES delivers flawless state of the art performance in digital to audio conversion. It also looks quite attractive. The only negatives are the cost and the rotary control. Not much else to say really. In case you are comparing it to its D400EX sibling, I think it performs a bit better yet costs less. I am happy to recommend SMSL D400ES DAC.
Test du Audiophonics HPA-S400ET par Audio Science Review (Amir)
Product typeDAC
InputsBluetooth 5.0
1* USB-B
1* I2S via HDMI
1* Optical Toslink
1* Coaxial
1* AES/EBU
Outputs1* Single-eneded stereo RCA
1* Balanced stereo XLR
DAC chipESS ES9039MSPro
USB interfaceXMOS XU316
OPA11*OPA1612
Line out amplitudeXLR : 5.2Vrms
RCA : 2.5Vrms
THD+N0.00005% (-125dB)(Un-Weighted)
Dynamic rangeXLR : 133dB
RCA : 128dB
SNRXLR : 133dB
RCA : 127dB
USB transmission modeAsynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX 10.6 or later
Linux
MQA decoderUSB
Optical
Coaxial
AES
MQA-CD decoderOptical
Coaxial
AES
Supported sampligf ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supported Bluetooth codecsAAC, SBC, aptX, aptX-HD, LDAC
Supply voltage100-240VAC
Consumption< 10W
Standby consumption< 0.5W
Dimensions (L*P*H)240*188*43mm
Weight1.8kg
ColorSilver
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ColorSilver
Remote ControlYes
Beau produit
Bonjour,
Aspect du produit convaincant, mise en place facile, le réglage nécessite quelques essais afin de trouver les bons paramètres, première écoutes un Poil fatiquantes.
Je suis confiant du rendu après le rodage.
Service audiphonics bon !
This review has been posted for SMSL D400ES DAC ES9039MSPro XMOS XU316 11x OPA1612 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA
With its D400ES DAC, SMSL is back on the scene by adopting the latest high-end DAC chip ES9039MSPro from ESS. Associated with very high quality...
