SMSL SU-10 Balanced DAC 2x ES9038Pro XMOS XU316 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA MQA-CD
The SMSL SU-10 is a high-end balanced DAC, benefiting from a rigorous design allowing it to provide a precise sound reproduction, as close as possible to the original signal. It is equipped with two ESS ES9038Pro digital to analog conversion chips, ensuring a particularly efficient decoding, with a very low level of distortion and noise. In combination with a state-of-the-art XMOS XU316 USB interface, the SU-10 is capable of playing high-resolution audio streams up to PCM 32bit 768kHz and DSD512, but also decoding MQA files.
By buying this product you get 99 loyalty points
Reference : 16865
999,00 €tax incl.
832,50 € tax excl.
Shipping date: 09-05-2025.
SMSL SU-10
SMSL SU-10 DAC Symétrique 2x ES9038Pro XMOS XU316 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA MQA-CD
The SMSL SU-10 is a high-end balanced DAC, benefiting from a rigorous design allowing it to provide a precise sound reproduction, as close as possible to the original signal. It is equipped with two ESS ES9038Pro digital to analog conversion chips, ensuring a particularly efficient decoding, with a very low level of distortion and noise. In combination with a state-of-the-art XMOS XU316 USB interface, the SU-10 is capable of playing high-resolution audio streams up to PCM 32bit 768kHz and DSD512, but also decoding MQA files. The converter stage also works in conjunction with a high performance CK-03 clock circuit, which reconstructs an accurate clock signal to minimize the jitter level.
The whole benefits from a careful manufacture. For example, there are no less than 21 OPA1612A OPAs in the conversion stage. The dual linear low noise power supply allows to provide an independent electrical signal to the analog circuit and to the digital section. Several voltage regulators ensure a high stability and reliability of this signal.
7 digital filters
In order to allow you to adapt the sound reproduction of the SU-10 to your taste and your audio system, the DAC provides seven digital filters, each providing a variation in tone.
Bluetooth 5.0
With its integrated Bluetooth 5.0 receiver chip, the SU-10 allows for convenient wireless use, making it possible to stream your music remotely directly from a smartphone or tablet for example. In addition, it supports high-definition codecs aptX, aptX HD and LDAC to obtain a very good sound quality in wireless.
MQA & MQA-CD
The SMSL SU-10 is able to decode the MQA (Master Quality Authenticated) format. This one allows to enjoy very high quality audio files, authenticated by the artist, the producer or the rightful owner, for a musical experience as close as possible to the studio recording. This type of file is notably available on the Tidal streaming platform.
MQA-CD is also supported by the SU-10. So by connecting it to your CD player, you can decode your MQA CDs and enjoy their quality.
1Screen
2IR receiver
3Multifunction knob
4Power connector
5USB-B input
6Optical input
7USB-C input
8Coaxial input
9I2S input
10Bluetooth antenna
11AES input
12Balanced XLR output
13RCA output
Test du SMSL SU-10 par Audio Science Review (Amir)
" The SU-10 is an excellently engineered DAC. It aims to squeeze the last bit of performance available. Such improvement is limited by how well I can measure it due to analyzer noise itself. We clearly have state of the art performance here. Besides performance we have nice new functionality in the form of two independent USB inputs and support for independent audio outputs."
Product typeDAC
InputsBluetooth 5.0
1x USB-B
1x USB-C
1x Optical Toslink
1x Coaxial
1x I2S via HDMI
1x AES
1x Balanced stereo XLR
Line output amplitudeXLR : 5.1Vrms
RCA : 2.6Vrms
THD+N0.00005% (-125dB)
Dynamic rangeXLR : 135dB
RCA : 128dB
SNRXLR : 135dB
RCA : 128dB
USB transmission modeAsynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11
Mac OSX 10.6 or later
Linux
MQA decoderVia USB / Optical / Coaxial / I2S / AES
MQA-CD decoderVia Optical / Coaxial / AES
Supported sampling ratesUSB : PCM up to 32bit 768kHz, native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial / AES : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supported Bluetooth codecsAAC, SBC, aptX, aptX HD, LDAC
Consumption< 30W
Standby consumption< 0.5W
Dimensions240*185*39mm
Weight1.86kg
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipES9038PRO
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
Remote ControlYes
6 reviews
SMSL SU-10 DAC
J'ai longtemps possédé un AURALIC VEGA de 2016 dont je fus très satisfait: dynamique, transparence, large scène sonore (son holographique), très précis mais pas analytique donc très musical....mais le SMSL SU-10 qui a la même signature sonore va encore plus loin... et d'une façon notoire (au moins 20%).
Je remercie Audiophonics pour son honnêteté puisque m'a longtemps conseiller de rester avec mon Auralic et de ne pas en changer inutilement pour un autre... mais c'était sans compter l'arrivée sur le marché du SMSL SU-10 avec un rapport qualité/prix exceptionnel.
This review has been posted for SMSL SU-10 Balanced DAC 2x ES9038Pro XMOS XU316 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA MQA-CD
Un rapport qualité/prix excellent
Ce DAC fourni une qualité de son exceptionnelle, grace à des composants de haut niveau, une conception moderne, une réalisation de qualité, il ne s'embarrasse de fonctions inutiles, il présente donc un taux de distorsion et un rapport signal sur bruit très faibles et cela s'entend sur ma chaine HiFi dotée d'enceintes Martin Logan ESL électrostatiques et d'ampli et préampli Classe A. Le son est d'une pureté exceptionnelle. Même les non-initiés sont séduits.
SMSL SU10
DAC is really excellent. Big and boldly soundstage. It is worth for the money. Recommended!
SMSLSu10
Excellentissime DAC.
trés trés bon dac
beaucoup de clarté et d'émotion c'est le top et une équipe a votre disposition ,merci audiophonics
The SMSL SU-10 is a high-end balanced DAC, benefiting from a rigorous design allowing it to provide a precise sound reproduction, as close as...
