SONCOZ LA-QXD1 DAC Balanced ES9038Q2M 32bit 768kHz / DSD512 XMOS Black
By buying this product you get 22 loyalty points
Reference : 14529
229,00 €tax incl.
190,83 € tax excl.
SONCOZ LA-QXD1
 ES9038Q2M 32bit / 768kHz DSD512
Very complete balanced digital / analog / DAC interface integrating dual SABRE ES9038Q2M chips and USB XMOS interface.
Its resolutely high-end circuit, its simple and compact construction as well as its very accessible interface make it an ideal solution for audiophiles looking for an easy-to-configure DAC for any high-fidelity installation.
Review by Audio Science Review
Usually balanced output comes at a cost of higher price as it is considered a premium feature. Not the case here. You get XLR output and importantly, with superbly low noise and distortion for a really budget price.
 test by the measurement forum Audio Science Review
ES9038Q2M DAC chip
The LA-QXD is a well designed DAC built on a ES9038Q2M Sabre 32-bit chip ntegrated in balanced mode.
This component belongs to ESS flagship series and is among the best current hardware solutions for high-fidelity audio decoding. It uses HyperStream 32 BIT 768kHz architecture with native DSD support. Each one of this chips is also equipped with advanced reconstruction filters and uses some of the finest dithering techniques available on the audio market.
ESS ES9038Q2M SABRE DACs are also very popular thanks to their ability to operate volume with almost no consequences on the audio bitrate.
USB interface & S/PDIF interface
The LA QXD1 has a USB input on a USB-B connector controlled by a XMOS U208 interface. The latter allows it to work directly from audio streams on your computer or any device with this type of connector.
A second separate USB connector is in charge of powering the device. This redundancy makes it possible to completely ignore the audio parasites induced by a non-isolated USB source. This power connector is USB-C to facilitate scenarios of nomadic use and battery power.
In addition to the USB input, the LA QXD1 has an S / PDIF interface. The latter allows it in the first place to decode the S / PDIF streams received on its oaxial & optical inputs with a 24-bit / 192kHz / DSD64 resolution.
In addition, the SPDIF interface is also connected to the USB interface as well as to a digital output on coaxial port. In addition to its DAC function, the LA-QXD1 can thus work as a digital interface able to interface its optical / coaxial and USB inputs to an S / PDIF coaxial output.This digital interface output offers various integration possibilities for occasionally or permanently connecting devices that do not have the appropriate inputs/outputs.
Simple and accessible control panel
The device is easily controlled using four buttons located on the front panel. These provide access to source selection, digital filter adjustment, volume control and mute functions.
A panel of four LEDs indicates the active output in real time and allows you to check that the device is powered up.
TypeDAC
Digital interface
ArchitectureBalanced
chip DACES9038Q2M
InputsUSB-B (XMOS)
Optical Toslink
Coaxial SPDIF
OutputsAnalog stereo RCA (single-ended)
Analog stereo XLR (balanced)
Digital Coaxial SPDIF
Sampling frequencyUSB: 32-bit / 768kHz PCM - DSD512 (native)
Optical 24-bit / 192 kHz PCM - DSD64
Coaxial: 24-bit / 192 kHz PCM - DSD64
Output LevelXLR: @ 4.0Vrms 0dBFS
CAR: @ ??2.0Vrms 0dBFS
Frequency response20Hz ~ 20KHz (± 0.18dB) XLR / RCA
Dynamic range> 124dB A-Weighted
THD + N<0.00015% @ 1kHz XLR / RCA
Crosstalk> 130dB @ 1kHz XLR / RCA
Output impedance200Ω XLR
100Ω RCA
Noise floor modulation
<4.3μVrms
Dimensions149.3 x 87 x 37mm
Weight475g
Package contents
LA-QXD1x1
USB-B male / male USB-A Cablex1
USB-C male / male USB-A Cablex1
OutputCoaxial SPDIF
DAC / ADC ChipES9038Q2M
Max sampling rateDSD512
Max sampling rate768kHz
Download
2 reviews
Très bon DAC
J'ai acquis ce Dac pour remplacer LE Dac AUDIOPHONICS U-SABRE USB 24Bit/96kHz ES9023 TCXO qui n'est plus reconnu par Windows 10 depuis une mise à jour récente.
Ce Soncoz LA QXD1 écrase le Dac audiophonic U sabre dans le registre médium. Médium beaucoup plus présent, aéré et défini. le grave quant à lui est en léger retrait et l'aigue est comparable au U Sabre. bref que du bonheur. je lui est adjoint une formule 1 en alimentation, l'ALLO SHANTI Alimentation Linéaire Régulée Double 5V 3A à 199€. les transitoires et les attaques des notes sont fabuleuses avec cette alimentation. Malgré la discontinuité du produit chez Audiophonic ( c'est bien dommage), on peut encore commander ce DAC sur certains sites.
This review has been posted for SONCOZ LA-QXD1 DAC Balanced ES9038Q2M 32bit 768kHz / DSD512 XMOS Black
Très bon DAC
Bon rapport qualité prix pour ce DAC. J'aime beaucoup la douceur et les détails qui sont produits par cet appareil. J'ai pu comparé avec le topping E30 que j'ai aussi chez moi. Le Soncoz est plus équilibré selon moi, alors que le E30 envoie des basses et a un punch débordant. Ces deux DACs me plaisent et ont trouvé leur place dans deux installations HIFI différentes. Un avantage du Soncoz, selon moi, est l'absence d'affichage sur le devant du DAC qui permet une intégration facile dans n'importe quel environnement.
Une remarque , j'ai remplacé le cable USB d'alimentation (USB-C male) fourni dans la boite du Soncoz par un cable de meilleure qualité. Le cable fourni, pour une raison qui m'échappe, avait un impact négatif sur la restitution sonore (le DAC est alimenté par une alimentation linéaire régulée d'Audiophonics de bonne qualité).
