TOPPING D70 PRO DAC ES9039SPRO XMOS XU316 Bluetooth 5.1 LDAC aptX-Adaptative 32bit 768kHz DSD512 Silver
The Topping D70 Pro DAC features many of the refinements of a high-end audio product. With high-performance chips, ultra-low jitter clocks, the latest interfaces and great versatility, this converter offers exceptional audio reproduction, characterised by magnificent transparency and richness of sound while offering practical and useful features.
By buying this product you get 55 loyalty points
Reference : 17728
559,00 €tax incl.
465,83 € tax excl.
Topping D70 PRO
TOPPING D70 Balanced DAC 2x AK4497 XMOS XU208 I2S 32bit 768kHz DSD512 Silver
TOPPING D70 PRO DAC ES9039SPRO DAC ES9039SPRO XMOS XU316 Bluetooth 5.1 LDAC aptX-Adaptative 32bit 768kHz DSD512 Noir
DAC ES9039SPro
The ES 9039SPro DAC chip from ESS is the current flagship of the brand, allowing an efficient and precise decoding. This chip allows it to reach a THD+N lower than 0.00008% @ 1Khz and a dynamic range of 128 db on the RCA output as well as a THD+N of 0.00006% @ 1Khz and a dynamic range of 133dB for the XLR output.
Moreover, these chips support high sampling rates, allowing you to enjoy your PCM files up to 32bit 768kHz and DSD up to DSD512 Native.
New I/V converter
The D70 Pro features a new converter to achieve excellence in audio reproduction. This circuit design allows for very low distortion and noise.
Bluetooth 5.1
This DAC supports the best Bluetooth formats such as LDAC, aptx-Adaptive and apt XHD. High resolution files can be transmitted to it for a superb listening experience, all with the convenience of wireless.
An extraordinary power
The power of the D70 Pro ensures a very rich and detailed level of sound reproduction.
Plug and Play: a very wide compatibility
The D70 Pro has a wide system compatibility; Windows 10, Windows 11, Mac OS, Linux, IOS, Android. Just connect it to your audio source and start playing music. The USB plug is based on the XMOS XU316 chip and a custom Thesycon driver and is therefore very stable.
A driver and a parameterization is necessary for the ASIO application on windows.
Connections & Features
With its multitude of features and connections, the D70 PRO from Topping will fit into the vast majority of audio systems, offering many options for use and installation. On the input side, the device offers AES/EBU, Coaxial SPDIF, Optical Toslink and USB.
On the output side, we find balanced XLR and unbalanced RCA. The D70 PRO allows you to select the output so as to send the audio stream only on one of them or on both at the same time.
In addition, the XLR 4V and RCA 2V outputs can be boosted to XLR 5V and RCA 2.5V.
1Color display screen
2Menu screen button
3Volume control
4Balanced stereo XLR output
5Stereo RCA output
6Coaxial input
7Optical Toslink Input
8Bluetooth antenna
9USB-B input
10AES/EBU input
1112V Trigger
12IEC socket/Power switch
Integrated preamp function
The D70 PRO also provides the function of a preamplifier since it has a volume controller. This volume control function can however be deactivated in order to be able to use the D70 Pro only as a DAC with output levels constantly at their maximums, i.e. 4Vrms for the XLR output and 2Vrms for the RCA output.
Customizable Filters
The D70 Pro allows you to switch from one mode to another easily. So you can switch from the default mode to the valve mode or the transistor mode quickly and enjoy a different listening experience. If you want to experiment with other types of sounds you can also adjust the different timbres to your taste.
12V trigger option
This function allows the D70 PRO to be controlled or to control other devices in order to turn on and off simultaneously.
A new screen with integrated controls
A new color screen is integrated in the D70 Pro as well as 3 control buttons for a better experience. Moreover this screen can display some information (FTT and VU) according to your needs and desires.
Remote control
Topping D70 DAC 2x AK4497 XMOS XU208 AK4118 32bit 768kHz DSD512
1ON/OFF button
2Volume +
3Previous source
4Volume -
5NC
6Filter selection
7Automatic power on
8Mute mode
9Output mode selection
10Next source
11NC
12NC
13Brightness screen adjustment
Test of the Topping D70 PRO by Audio Science Review
"I'm pleased to recommend the Topping D70 Pro Sabre stereo DAC. Not only does it perform well, but it also has the key features you'd expect from a DAC (such as a spectrum analyzer, for example)."
Dimensions
Product typeDAC
DAC ChipES9039SPRO
USB interfaceXMOS XU316
Input1x Optical Toslink
1x USB-B
1x Coaxial SPDIF
1x AES/EBU
Bluetooth
Supported sampling ratesUSB: PCM Up to 32bit 768kHz / DSD Native Up to DSD512 / DSD DoP Up to DSD256
Coaxial, Optical, AES: PCM Up to 24bit 192kHz
Supported Bluetooth codecsBluetooth : SBC, ACC, LDAC,aptX, aptX HD, aptX Adaptative
Ouput1x XLR balanced
1x RCA unbalanced
THD+NRCA : <0.00008% @ 1kHz A-Weighted
XLR : <0.00006% @ 1kHz A-Weighted
THD @ 90Bw (Not Weighted)RCA : <0.0004% @ 20-20kHz
XLR : <0.0002% @ 20-20kHz
SNRRCA : 128dB @ 1kHz A-Weighted
XLR : 133dB @ 1kHz A-Weighted
Dynamic RangeRCA : 128dB @ 1kHz A-Weighted
Fréquency responseRCA : 20Hz - 20kHz (+/-0.5dB) / 20Hz - 40kHz (+/-0.2dB)
XLR : 20Hz - 20kHz (+/-0.2dB) 20Hz - 40kHz (+/-0.2dB)
Output voltageRCA : 2.1Vrms @ 0dBFS (4V Mode) / 2.5Vrms @ 0dBFS (5V Mode )
XLR : 4.2Vrms @ 0dBFS (4V Mode/ 5Vrms @ 0dBFS (5V Mode )
Noise RCA : <1.0µVrms
XLR : <1.0µVrms
Channel crosstalkRCA : -128 dB @ 1Khz
XLR : -140 dB @ 1Khz
Channel balanceRCA : 0.3dB
XLR : 0.3dB
Output impedanceRCA : 50 Ohms
XLR : 100 Ohms
Power supply100V-220V AC 50Hz/60Hz via IEC (cable supplied)
Housing materialAluminium
Dimensions22.2 x 17.6 x 4.8cm
Weight1.9kg
ColorSilver
Package1x Topping D70 PRO
1x IR remote control
1x USB cable
1x Power cable
1x Bluetooth Antenna
1x Manual
1x Warranty card
InputAES/EBU
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
Remote ControlYes
Marc
After a few weeks using this DAC as a source I find it neutral and highly resolving with impressive dynamics. It does not inject harmonic richness but neither does it sound cold and sterile like som older high tech DACs. With warm and rich music files it reproduces that very well. The high midrange and treble are smooth and natural, and even with suboptimal recordings this range is not "irritating" (even though it reveales the flaws). Bass is deep tight and punchy. It does not exaggerate söundstage like some R2R DACs but when the recorded soundstage is large it preserves that combined with pinpoint imaging.
I suggest pairing it with a reference class preamplifier to preserve dynamics, ease/flow and compatibility with all poweramps.
I find it a small but clear step up compared to my RME DAC2fs.
This review has been posted for TOPPING D70 PRO DAC ES9039SPRO XMOS XU316 Bluetooth 5.1 LDAC aptX-Adaptative 32bit 768kHz DSD512 Silver
The Topping D70 Pro DAC features many of the refinements of a high-end audio product. With high-performance chips, ultra-low jitter clocks, the...
