TOPPING DX1 DAC Headphone Amplifier AK4493S XMOS XU208 32bit 384kHz DSD256 Black
Topping unveils with the DX1 a compact, affordable and yet powerful DAC and headphone amplifier combo. It benefits from an optimized design allowing an efficient digital/analog conversion as well as a robust headphone amplification.
Reference : 16837
99,00 €tax incl.
82,50 € tax excl.
Topping DX1
Topping DX1 DAC Amplificateur Casque AK4493S XMOS XU208 32bit 384kHz DSD256
AK4493S DAC & XMOS XU208 USB Interface
The DX1 features the brand new AKM AK4493S DAC chip. This ensures a precise and musical conversion, while allowing, in association with the USB XMOS XU208 interface, the support of high resolution audio streams, up to PCM 32bit 384kHz and DSD256.
Discrete LNRD
The Topping DX1 uses a discrete LNRD (Low Noise Reference Driver) circuit to effectively filter out noise and interference from the USB power supply. As a result, the power supply stage is able to provide the DX1's audio circuitry with a clean and stable electrical signal.
Le volume de la sortie ligne est fixé à son niveau maximum et n'est pas ajustable.
Les sorties casques et la sortie ligne sont actives simultanément.
Product typeDAC and headphone amplifier
DAC chipAKM AK4493S
Input1x USB-B
Outputs1x Stereo RCA line out (fixed volume)
1x Jack 3.5mm headphone output
1x Jack 6.35mm headphone output
Native DSD up to DSD256
DSD DoP up to DSD128
DAC Parameters (USB Input @ 44.1kHz)
THD+N @ 1kHz, A-Weighted< 0.0002%
THD @ 20Hz-20kHz, 90kBw< 0.0006%
SNR @ 1kHz, A-Weighted120dB
Dynamic range @ 1kHz, A-Weighted120dB
Frequency repsonse20Hz - 20kHz (±0.3dB)
20Hz - 40kHz (±0.7dB)
Output level2.0Vrms @ 0dBFS
Crosstalk @ 1kHz-112dB
Channel balance0.3dB
Output impedance22Ω
Headphone amplifier parameters
THD+N @ 1kHz, A-Weighted< 0.0003% @ 200mW, 32Ω
< 0.0002% @ 45mW, 300Ω
THD @ 20Hz-20kHz, 90kBw< 0.003% @ 200mW, 32Ω
< 0.001% @ 45mW, 300Ω
SNR @ Max Out, 1kHz, A-Weighted118dB
Dynamic range @ 1kHz, A-Weighted118dB
Frequency response20Hz - 20kHz (±0.3dB)
Output level2.2Vpp @ G=L
11Vpp @ G=H
Noise @ A-Weighted< 1.0µVrms
Crosstalk @ 1kHz-86dB
Gain-2dB (Vrms/FS) @ G=L
12dB (Vrms/FS) @ G=H
Output impedance< 0.7Ω
Output power2x 280mW @ 32Ω, THD+N <0.1%
2x 190mW @ 64Ω, THD+N <0.1%
2x 51mW @ 300Ω, THD+N <0.1%
Load impedance> 8Ω
Dimensions100 x 98 x 32mm
Package1x Topping DX1
1x USB-B cable
OutputJack 3.5mm
OutputJack 6.35mm
DAC / ADC ChipAK4493S
Max sampling rateDSD256
Max sampling rate384kHz
5 reviews
Handy
Cute and handy little hp-amp. Enough power for everyday use. Only minus is the volume control knob which is a bit slippery.
This review has been posted for TOPPING DX1 DAC Headphone Amplifier AK4493S XMOS XU208 32bit 384kHz DSD256 Black
Bien, mais...
Bonjour, acheté pour remplacer un FX 01, parfait pour mes besoins, mais dénué d'une prise casque, j'ai donc opté, sur les conseils toujours avisés, compétents et aimables d'Audiophonics pour ce dac/ampli casque qui vaut quand même près de trois fois le prix du FX 01. Mes premières expériences ont été très décevantes, autant sur mes enceintes amplifiés que sur les différents casques ou écouteurs branchés dessus.
Volume faible et métallisations des aigus qui vrillent les oreilles, bref rien d'agréable. Frustré, j'ai eu l'idée de remplacer le câble USB fourni avec le DX 1 par celui de l''antique et modeste FX 01.
Surprise : le volume était deux fois plus fort, mieux défini, beaucoup plus fin, quelle que soit la définition du son d'origine et la qualité des écouteurs... Morale de l'histoire : c'est un très bon appareil, mais livré avec un câble de grille-pain. Même si vous ne croyez pas qu'un câble informatique n'a aucune incidence sur le son, puisqu'il n'est censé transmettre que des données informatiques, mon expérience me prouve le contraire.
Je m'étonne que le câble blindé fourni avec le DAC le moins cher au monde, le FX01, soit infiniment meilleur que celui fourni avec un appareil très bon mais trois fois plus cher.
Sinon, pour ce qui est de la qualité du DX 1 en lui-même, et sur le service Audiophonics, rien à dire, ou alors que du bien.
Amicalement.
DAC Topping DX1 suite ....
Essais avec alim linéaire et alimentation batterie (avec un câble USB en "Y") concluants : l'amélioration sur la dynamique dans le grave et l'aération en vaut le coup.
DAC Topping DX1
Cette "petite boite noire" fonctionne à merveille, immédiatement reconnue sous Android et win 10 (le pilote ne sert à rien), après instal nécessaire du pilote sous Win 7 (oui j'uilide encore W7). Avoir un DAC "direct" et un ampli casque avec volume dans la même boite qui tiendrait dans une poche ! Les 2 sorties fonctionnent simultanément et indépendamment. Reconnue aussi par equalizer APO. Le son est très clair et aéré, pas trop "sec", plutôt "moelleux", très agréable, peut-être pas hyper analytique ou dynamique dans le grave, mais précis et détaillé dans le reste de les fréquences. Elle mérite un test avec une alimentation linéaire classique (pas à découpage) indépendante, pour voir si la complication d'installation en vaut le coup.
Magnifique ampli dac qualitatif et peu onéreux.
Le boitier lui même est bien plus esthétique que je m'y attendais.
Très pratique, bouton en facade, alimenté par Usb. L'ampli est surprenant. Largement assez puissant pour mes casques 32 et 250 Ohms. Les mesures montent une qualité de reproduction du Dac bien supérieur à ce qui est audible à l'oreille humaine. Donc parfait de ce coté. L'ampli lui même, je ne vois rien à lui reprocher. La garantie étant prise en charge par Audiophonic, je suis tranquille en cas de soucis. Pour finir, la livraison a été très rapide comme d'habitude. Aucun regret pour cet achat que je suis près à renouveler en cas de besoin.
Topping unveils with the DX1 a compact, affordable and yet powerful DAC and headphone amplifier combo. It benefits from an optimized design...
