TOPPING E70 VELVET DAC AK4499EX XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Silver
With the E70 Velvet, Topping offers a new version of the excellent E70 DAC featuring the new AK4499EX high-end digital-to-analog conversion chip from AKM. For the rest, it takes the excellent technical basis of its elder brother, combining a careful design and high-end components for exceptional sound performance with smart and practical features, such as Bluetooth, a 12V trigger or an adaptable output level.
4.8 / 5
By buying this product you get 34 loyalty points
Reference : 17119
349,00 €tax incl.
290,83 € tax excl.
Last items in stock !
Shipping date: 14-04-2026.
Topping E70 Velvet
Topping E70 Velvet DAC AK4499EX XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Argent
AKM AK4499EX DAC
The Topping E70 Velvet embeds within its digital/analog conversion stage the brand new DAC chip from AKM, the AK4499EX, the new flagship of the manufacturer. This converter benefits from a switched resistor architecture using the proprietary VelvetSound technology. It uses the latest high quality conversion technologies to provide the most vivid and realistic sound reproduction possible.
A state-of-the-art I/V conversion circuit
The E70 Velvet uses the excellent I/V conversion circuitry implemented by its big brother. It is designed to ensure low distortion and low noise, while taking up less space. It is here pushed to its limits to allow the DAC to reveal its full potential.
Bluetooth 5.1
Equipped with a Qualcomm QCC5125 Bluetooth 5.1 receiver chip, the E70 Velvet lets you stream your music remotely directly from your smartphone or tablet. It also supports the high-resolution transmission codecs aptX, aptX HD, aptX Adaptive and LDAC, guaranteeing high-quality playback over Bluetooth. In addition, the E70 Velvet bypasses the conversion stage of the Bluetooth receiver to use the much more powerful AK4499EX DAC in order to provide the most faithful sound reproduction possible.
XMOS XU316 USB Interface
The USB input of the Topping E70 Velvet is associated with a latest generation XMOS XU316 interface with custom Thesycon driver. This powerful interface supports high resolution audio streams, up to PCM 32bit 768kHz and DSD512, for a very high quality listening.
Trigger 12V
The E70 Velvet features a 12V trigger with active (trigger output) and passive (trigger input) control. With only a single 3.5mm Jack cable, the E70 Topping can be switched on and off in sync with your other equipment with a 12V trigger interface.
Selectable output modes
The E70 Velvet provides balanced XLR and single-ended RCA output. The input is selectable and allows to activate only one or both simultaneously. Moreover, Topping offers a smart feature, allowing you to adjust the level of these outputs according to your use and the desired integration. Thus, the level of the XLR output can be changed from 4V to 5V and the RCA output from 2V to 2.5V.
1ON-OFF / input selection button
2Screen
3Volume button
4Coaxial input
5Bluetooth antenna connector
612V trigger input
7Balanced XLR output
8Single-ended RCA output
9Optical Toslink input
10USB-B input
1112V trigger output
12Power supply input
13Power button
Product typeDAC
InputsBluetooth 5.1
1x USB-B
1x Coaxial
1x Optical Toslink
1x Balanced stereo XLR
DAC chipAKM AK4499EX
Bluetooth receptionQCC5125
USB interfaceXMOS XU316
Supported Bluetooth codecsAAC
SBC
aptX
aptX HD
ptX LL
aptX Adaptive
LDAC
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Measurements
DAC E70 Velvet parameters (line out / USB input @ 96kHz)
RCAXLR
THD+N (A-Weighted)< 0.00008% @ 1kHz< 0.00006% @ 1kHz
THD @ 90kBw (Non-Weighted)< 0.0002% @ 20Hz-20kHz< 0.0002% @ 20Hz-20kHz
SNR (A-Weighted)125dB131dB
Dynamic range @ 1kHz, A-Weighted125dB131dB
Frequency response20Hz-40kHz (±0.3dB)
20Hz-40kHz (±1.0dB)
20Hz-40kHz (±0.2dB)
20Hz-40kHz (±0.8dB)
Output level2.1Vrms @ 0dBFS (Mode 4V)
2.5Vrms @ 0dBFS (Mode 5V)
4.2Vrms @ 0dBFS (Mode 4V)
Noise (A-Weighted)< 1.3µVrms< 1.3µVrms
Channel crosstalk-130dB @ 1kHz-143dB à 1kHz
Channel balance0.3dB0.3dB
Output impedance50Ω100Ω
ColorSilver
Dimensions (L*P*H)200*138*44mm
Package1x Topping E70
1x Remote control
1x USB cable
1x Power cable
1x Bluetooth antenna
DAC / ADC ChipAK4499EX
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
Remote ControlYes
12 reviews
Bon DAC
DAC dans sa version VELVET et qui contiens la fameuse puce AK4499EX et sa compagne l'AK4191.
A l'écoute c'est suave et terriblement chouette sur les voix, il n'y a peu être pas mieux en fait de ce côté là. Les timbres sont très bien aussi et pas fatigant du tout sur les aigus (parfois pénible sur les puces ESS).
Sur les voix j'ai été très déçu du R2R Musician Pegasus pourtant encensé, comme quoi il faut vraiment écouter avant d'acheter et de se faire son propre avis.
Mais ca peut manquer de détail et de spatialisation versus d'autres puces type ESS ou le D90 III discrete de la même marque. Notez que c'est un poil plus sombre aussi en tonalité mais moins fatiguant a l'écoute.
"Velvet Sound" oui clairement.
Très bon rapport qualité-prix.
Je pense que ce DAC fera merveille pour un ampli un peu sec et un système un peu brillant.
Pas parfait, mais je le conserve néanmoins dans mon installation pour des écoutes sur les voix et quand je veux une ambiance plus "velours". Pour du détail et de la précision là je vais plutôt sur le D90 III Discrete, voir du ESS.
Rapport qualité-prix imbattable, ambiance "veloutée" au RV
This review has been posted for TOPPING E70 VELVET DAC AK4499EX XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Silver
Excellent produit
Je me suis procuré ce dac suite a différents avis trouvés ici et la. Et bien je suis enchanté par ce produit. Je voulais un dac akm sortant d un eversolo z8 sabre. Tout est bien présent bien détaillé mais jamais criard. Basses profondes. Medium sublimes. A recommander sans hésitation. L interface pourrait être améliorée mais une fois bien configuré on y touche presque plus. Un petit plus pour le réglage de la balance qui est très pratique dans certains cas. Merci à Audiophonics.
Interface pas à mon goût
Je l'ai retourné car j'ai été déçu de l'interface en façade :
- Bouton "tactile" unique à gauche (il faut appuyer plusieurs fois pour changer la source)
- Molette du volume molle et légère, et tourne à l'infini.
- Affichage LCD plutôt cheap pour le tarif du produit je trouve
La télécommande a rien d'exceptionnelle, les boutons sont pas très clairs.. Bizarement, elle a perdu le DAC et s'est mise à contrôler ma TV au bout de quelques minutes..
En comparaison avec un fiio à 200€, je trouve la qualité de finition et fabrication supérieure chez Fiio.
Je n'ai pas testé suffisamment pour juger de la qualité du son.
Amélioration et aération
J'étais en RCA avec un octavio stream g1 sur un marantz pm 6003 et une paire de dittons 442 recapé. Le son était bien mais depuis que j'ai mis le topping e70 velvet en action ( câble optique sur l'octavio et USB sur le pc ) le son est plus aéré et la scène sonore plus précise avec une meilleure séparation des instrus . Très content de mon achat . Prochain upgrade l'ampli pour aller chercher plus de chaleur et dynamique. Certainement un pm 8006 ou un marantz ki .
Awesome!
Plently of technical reviews online (which also made me buy it), so in short:
- Great item with amazing sound
- Great price
- Great service with fast shipping
With the E70 Velvet, Topping offers a new version of the excellent E70 DAC featuring the new AK4499EX high-end digital-to-analog conversion chip...
