TRASAM DS5 Balanced DAC ES9028PRO 24bit/192kHz DSD128 XMOS Bluetooth 5.0
TRASAM's DAC DS5 is based on a SABRE ES9028PRO chip with a USB XMOS interface and a Bluetooth chip CSR-8675 Apt-X HD, which allows it to benefit from an excellent connectivity while supporting high sample rates.
By buying this product you get 32 loyalty points
Reference : 14092
329,00 €tax incl.
274,17 € tax excl.
Last items in stock !
Shipping date: 26-06-2025.
Please note : the power cable is not delivered with this product
The right cable can be found (EU plug) by following this link.
Trasam DS5 DAC with volume
DAC ES9028PRO XMOS OPA2172 / 384kHz / 24-bit DSD128
Equipped with a well-builtoutput stage, it proposes a single-ended output, a balanced output and a front headphone outputs . Each output is subjected to a volume control operated by a rotative knob located on the front of the device.
A discrete and readable screen shows in real-time the active source and the sampling rate of the stream being decoded. It allows to verify that the digital / analog conversion of your high-resolution files runs as expected.
DAC ES9028PRO ESS SABRE
Equipped with a DAC ES9028 PRO, the DS5 offers the famous Hyperstream architecture, with its digital filter operating in frequency and time correction. This technology offers very high detail while limiting distortion and jitter (time digital attenuator).
Real component of choice for high fidelity applications, the chip 9028PRO has a decoding capability on 8 channels but is configured to work on two tracks (stereo) to expand and clarify  the soundstage as much as possible. This chip is found in a plethora of very advanced high-fidelity devices and can support sample rates up to 384kHz.
Extensive connectivity
Ideal to connect multiple sources devices on the same amplification system, the DS5 can receive digital audio stream via its USB ports (PC-USB & USB-OTG), S-PDIF (Optical & Coaxial) and Bluetooth apt-X HD.
Bluetooth and USB-OTG provide easy-to-set connections with a wide range of mobile devices. USB-PC port (USB-B female) and S-PDIF are used to connect to both a computer / streamer dedicated DVD / Blu-Ray player / TV and a game console simultaneously. A button on the front panel allow easy and quick switch from one source to another.
Each entry is controlled by an electrical relay to avoid thumps and parasitic noise during source change. This is very useful to protect the speakers / amplifiers and it  avoids the user having to shut down each source before sending it to the DAC.
Bluetooth apt-X HD
The DS5 embeds a Bluetooth chip CSR8675 which supports apt-X HD norm. This technology allow audio flows with sampling rates up to 24-bit / 48kHz with a 576kbps rate.
The chip automatically adjusts the compression ratio to make the most of bluetooth's bandwidth and avoid losing resolution when not absolutely essential to meet the needs of the protocol. Used with audio in CD quality files, the loss on Bluetooth transmission is imperceptible.
Efficient output stage
The output stage works with low noise and high performanceoperational amplifiers OPA2172. These are mounted on removable DIP-8 port to allow changes and rapid comparative listening tests. The output stage provides a level of 2V line output with very low distortion (0.003%).
The DS5 provides a balanced output on RCA connector, an unbalanced output XLR-3 Pin connector and a 3.5mm headphone jack on the front panel.
The headphone output is capable of driving high loads with a comfortable reserve of power (500mW @ 16Ω / 50mW @ 600Ω).
Linear regulated power supply
A linear regulated power supply with isolated toroidal transformer provides a stable current with a precise filtering regulation / stage .
The whole circuitry is protected in a 100% aluminum housing , which effectively prevents noise and interference noise uptake via the power stage.
TypeDAC (digital to analog converter)
chip DACES9028PRO
USB interfaceXMOS
inputsOptical x1
Coaxial x1
USB x1
Bluetooth
OutputsStereo RCA (unbalanced)
XLR-3 stereo (balanced)
bluetooth standard5.0 APT-X HD
sampling rate supportedUSB:
- up to 192 kHz 24-bit (PCM)
- Up DSD128 (native DSD)
Coaxial:
- up to 384kHz 24-bit (PCM)
- DSD up DSD128 (DOP)
Dimensions240 x 56 x 200mm
Weight2000g
Package Contents
1xDAC DS5
1xmale-B USB cable to male micro-USB
1xmale-B USB cable to the USB-A male
1xBluetooth antenna
OutputJack 3.5mm
OutputJack 6.35mm
DAC / ADC ChipES9028PRO
Max sampling rate192kHz
Max sampling rateDSD128
TRASAM's DAC DS5 is based on a SABRE ES9028PRO chip with a USB XMOS interface and a Bluetooth chip CSR-8675 Apt-X HD, which allows it to...
