MUSICIAN TAURUS DAC R2R
This Taurus balanced R2R DAC from Musician is a high-end DAC incorporating top-of-the-range components and delivering incredibly rich, clear sound reproduction.
By buying this product you get 419 loyalty points
Reference : 18569
4 190,00 €tax incl.
3 491,67 € tax excl.
Shipping date: 27-05-2025.
MUSICIAN TAURUSDAC R2R Balanced OS/NOS I2S 32bit 1536kHz DSD1024 OCXO Black
DAC Musician Taurus photo
The Taurus R2R balanced architecture is complemented by two independent FPGAs to control the decoding of each channel via its four R2R networks composed of Panasonic resistors (0.005% accuracy). This prevents linear errors while maintaining high decoding speed and extremely low digital noise. The Taurus DAC's circuitry is completed by an Altera main FPGA control chip, two 49.152MHz and 45.1584MHz OCXO crystal oscillators, and an ARM STM32F446 CPU chip linked to a proprietary USB interface solution. This combination enables the Taurus DAC to accept high-resolution PCM 24bit 1536kHz and native DSD streams up to DSD1024.
Musician Taurus DAC highlights
Musician Taurus: proprietary digital filter technology
The Taurus DAC uses digital filter technology operating in Over Sampling 16x mode. Each filter level has a 32-bit input resolution, enabling a considerable increase in dynamic range and a natural, delicate sound reproduction.
Musician Taurus: high-end components
The combination of components selected by Musician for its R2R Taurus DAC delivers exceptional performance.
Photo of the Musician Taurus R2R circuits
R2R array
Each channel is equipped with two Panasonic resistor networks, each with a dedicated FPGA. This ensures very low levels of noise and distortion.
Photo of the Musician Taurus oscillators
Thermostatic crystal oscillators (OCXO)
Thermostatic crystal oscillators provide outstanding frequency stability for extremely low jitter decoding.
Photo of the main Altera FGPA chip in the Musician Taurus DAC
Altera FGPA chip
Altera's main FPGA chip is used to shorten the signal path and avoid any coloration that might interfere with high-purity sound reproduction.
Photo of the STM32F446 chip in the Musician Taurus dac
USB solution
Musician's proprietary USB interface is coupled with an STM32F446 driver chip to support very high-resolution streams.
Musician Taurus: two clock outputs
The two clock outputs, 49.152MHz and 45.1584MHz respectively, can be used to synchronize a wide range of audio devices.
Photo of Musician Taurus clock outputs
Photo of the Musician Taurus power transformer
Musician Taurus: an optimized linear power supply
The power supply stage of this R2R DAC features a 250 W O-core transformer coupled with LT1763 and LT3045 voltage regulators for efficient filtering. This guarantees a low-noise, highly stable power supply.
Pinout I2S
The Musician Taurus has been designed to offer broad compatibility via its I2S input, thanks to phase adjustment accessible as follows:
  1. Select I2S-A1 or I2S-A2 input.
  2. Press the PHASE button in the I2S pin function setting to switch the I2S pin configuration.
  3. Stop the operation once the correct settings are in place, and the Musician Taurus will exit setting mode after 5 seconds.
I2S input diagram
The comprehensive connectivity of the Musician Taurus DAC
Schéma de la connectique du DAC Musician Taurus
1Source selection (-)
2Phase selector
3OS/NOS button
4"Mode" button
5Source selection (+)
6ON/OFF button
7Mute mode
8XLR balanced output
9Unbalanced RCA output
10Clock outputs
11SPDIF coaxial input
12Toslink optical input
13AES/EBU input
14I2S inputs via HDMI
15USB-B input
16Power connector
Musician Taurus dimensions
Product typeDAC R2R
Inputs1x USB-B
2x I2S LVDS via HDMI
1x AES/EBU
1x Optical Toslink
1x Coaxial
Outputs1x RCA stereo unbalanced
1x XLR stereo balanced
USB interface STM32F446
Supported sample rateUSB / I2S: PCM up to 32bit 1536kHz, DSD up to DSD1024, DSD DoP up to DSD64
Coaxial / Optical / AES: PCM up to 24bit 192kHz, DSD DoP up to DSD64
Output levelRCA: 2.5V
XLR: 4.3V
Sampling modeNOS (Non OverSampling)
OS (OverSampling)
Distortion rate< 0.0015% (20Hz-20kHz, 0dB)
Frequency response 20Hz-80kHz
SNR> 127dB
Separation> 132
Phase0.001 deg
Dimensions380 x 420 x 95mm
Weight5.6kg
Package1x DAC R2R Musician Taurus
1x Power cable
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipR2R LADDER DAC
Max sampling rate1536kHz
Max sampling rateDSD1024
MUSICIAN TAURUS DAC R2R Balanced OS/NOS I2S OCXO 32bit 1536kHz DSD1024 Black
This Taurus balanced R2R DAC from Musician is a high-end DAC incorporating top-of-the-range...
